Question about Sony RDR-GX355
Video Recorder is in DV mode
I was trying to finalize a dvd with the recorder and I got into a DV mode that is now displayed on the recorder screen. I cannot bypass it, completely unplugging the recorder does not reset it and I cannot now play any dvds or record. I am stuck in this mode and there is nothing in the manual that tells me how to get out of it. Please help!!!!!!!
Try switching the input button on top right of your remote. it has 3 stages, line 1, line 2 and dv mode.
Posted on Apr 20, 2008
Want to copy vhs to dvd.
I convert VHS to DVD using a Toshiba DVD Recorder that I purchased from Costco a few years back. I plug the VCR into the DVD recorder using RCA jacks, press PLAY on the VCR and REC on the DVD recorder and let it sit and record. I can record up to 8 hours of video onto one DVD at low quality. After this, I finalize the DVD so it can be read on other DVD players.
Jan 03, 2012 | Hitachi DV-PF33U DVD Player/VCR
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
SCREEN SAYS "SAFE" ?DO IDO TO GET RID OF IT???????/
To remove "SAFE" from the front display, using the remote control, press and hold "INFO" for 5 seconds until it disappears. This was probably acitivated while you stopped a recording which can trigger it, of you may have activated "Safe" by pressing the INFO button several times. This is to prevent access of the recorder by locking all controls. This is for the DVD Recorder/VCR combo VR320 and the 1st generation DvD Recorder DVR-130.
Even though this was a product I regret purchasing, it isn't as bad a people make it out to be. It works best with DV cable recording from 1 Hour Mini-DV tape camcorders to 1 Hour XP Record DVD mode. It is probable one of the best. Only issue I have is when you try playing a finalized DVD-R disc in another DVD player, there is a chance it might not work because of the Highest quality 1 Hour record mode. Standard is 2 Hour SP. You will have to burn an exact copy using DVD copy software on your computer to DVD-R. This will fix the problem.
May 31, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Sony RDR-GX355 Logo
172 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
