Question about ASUS M2N-MX Motherboard
Slow detect Two IDE Device
When M2n-MX boot , it is slow in detecting two IDE device.
It take 1 min to detect both of them then i can start windows.
But when i disconnect one of them , there is no problem.
I have HDD 80 + DVD ROM and connect both of them with IDE cable.
  • iranmorteza Apr 18, 2008
    my probelm fixed
    My IDE cable was not connect correctly.
    Because i connected inverse
    i connect the side that must connect to motherboard,to DVD ROM.
    it resulting in slow detecting.
    the IDE cable has three part.Two of them are near selves.these parts must connect to HDD and DVD ROM.and the part that is far, mst connect to motherboard.
    Problem Solver:
  • 5 Answers
Similar problem here... Doing an in-case update from a perfectly reliable system. CD Burner and IOMega ZIP on the IDE cable and half the time the Burner doesn't reset at power on. I've tried two different power supplies, changed cables, and so on.
If I use either drive alone no problem... put them both on the cable and no go.
Checking the CD Burner on the bench, it will reset every time I give it power. But not so on the motherboard...
I'm thinking there's an IDE timing problem.
Posted on Apr 16, 2008
  • LD Blake Apr 17, 2008
    Well, I think I found the answer to my problem... and as Ekse said it's about jumpers....
    I have a CD-Rom and Zip disk on the same cable. They worked fine on my older (slower) system but not on the Asus board. Checking around the net last night I discovered there are at least 5 differenct versions of the same basic Iomega Zip disk.
    It turns out mine (and IDE/ATAPI 100) has an error on the sticker telling you how to set the jumpers. There are 3 possibilities, Cable Select, Slave and Master. The sticker says to use the left set of pins on the header for CS, the right set for Master and remove the jumper for slave... turns out this does work but the actual jumper setting for slave is to put the jumper on the center set of pins.
    Did it, now everything seems to be working.
    Now the question... How did I get away with that for so long???
  • ASUS Master
  • 13,433 Answers
1st make sure both jumpers are set correctly, the one in the end of the ide cable as master and the other in the middle of the cable as slave
you can also try connecting both with separate ide cables.
If you need more assistance let me know, I'm here to help
Posted on Apr 06, 2008
  • Ekse Apr 19, 2008
    Good job guys, now if you could give me a Fixya rateing that would be awesome :-)
When i reboot my pc, it say fress f11 for bbs popup?
The BBS Popup is to boot from a selected device, if you have Windows on your Hard Drive just boot from your HDD.
Nov 28, 2017 | Intel Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Hello sir , i installed windows7 in my pc but i cant hear sound. help me to solve this problem. my mother is M2N-MX SE PLUS
Hi vinayan092, The Asus website still do not have the audio driver for this model, try installing the windows Vista driver on this link http://uk.asus.com/Motherboards/AMD_AM2/M2NMX/#download, if you have installed this successfully, you can try to check in device manager if windows detected this successfully.
Aug 06, 2011 | ASUS M2N-MX Motherboard
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Board not detect the hard disc
Check on the jumper setting of the ide and power cable
check if the ide cable is connected properly on ur mother board/try reverse if u are not sure it doesnt ur hardware.
Start on power button the then click on on delete continuesly until the cmos setup will appear then check ur hardisk and ur boot secquence.
sometime not delete are using using in opening cmos sometime f2 or whatever assign.
Use fdisk/to check ur partition/after that reformat in these case u can easily conclude if ur hardisk is bad or not
Jun 10, 2009 | ASUS M2N-MX Motherboard
MY computer is not booting when i connect my new DVD.
Please make sure that your HDD and DVD ROM drives are getting detected in BIOS. Are you using IDE or SATA drives?
May 19, 2009 | ASUS M2N-MX Motherboard
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Dave
Nov 11, 2008 | ASUS M2N-MX Motherboard
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
ASUS M2N-MX Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
