Question about Samsung SCX-4216F All-In-One Laser Printer
Remote access The menu indicates online access to the fax function is available. I understand this to mean that when it is on fax/phone, when the phone is answered, if it is a fax, a number can be entered to start the fax function. Am I correct, and if so, how do I set up this feature. Brian Keller
  • 161 Answers
While hearing the fax tone, dial asterisk-9-asterisk and hang the phone.
Posted on May 29, 2008
SOURCE:
"Failed to read the PC-FAX Phone Book"
Try this
Browse to Control Panel > Administrative tools > Computer management > Services and Applications > Services
Locate the following services:
1. Telephony
2. Network Connections
3. Remote Access Connection Manager
4. Remote Access Auto Connection Manager
Right click and select Properties. On the General tab, next to Start Up type, select Automatic followed by OK.
May 09, 2014 | Epson Artisan 810 AllInOne InkJet Printer
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
How can i access the menu without the remote control?
On older Televisions such as the one you have listed, you cannot access those menus without a remote control. Just to make sure I skimmed the user manual found here. The only suggestion I have is to get a universal remote with a menu button. Dont forget to check with your other remotes to see if they have universal functionality. Most receivers (surround sound units) have multi-function remotes. Also check your satellite or cable remotes to see if they have universal functions. You can tell, because they will have multiple buttons that say things like "TV, AUX, CABLE, ETC" If so, you can program one of these remotes (or grab one at most electronics stores to program) and have your menu available to you.
Also, check the link to make sure there isnt some functionality hidden away that I didnt see.
Cheers!
Feb 23, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Cannot access menu
I tried every number code listed on the website for "Sears" and finally found one which gave me menu access. Some codes evidently work for some functions, but not for all.
Jun 29, 2009 | One For All URC-4330 Remote Control
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
We have a Canon CFX L4000. We have moved and have a new number for our fax machine. I do not find a menu or program button on the machine. It has a function and set button but they are of no help. How can...
I fixed this with the help of online chat with one of your experts Rylee Smith. I pushed the function button then the Data (01) button then used the up and down arrows to scroll through the menu to set my new phone # and how many rings would be used, etc. Thanks.
Jan 11, 2009 | HP OfficeJet V40xi InkJet Printer
Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
Aug 27, 2007 | Panasonic PV-7661 VCR
Samsung SCX-4216F All-In-One Laser Printer Logo
50 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
