Epson c42 printer ink replacment
Hi for got to take strip off colour cartridge now forgotten how to get to move out to take off strip blonde moment help lol
  • 667 Answers
Blonde moment huh? Likely story. Follow this link for the manual for your printer. You want page 27 which will show with pictures ( for you blondes ) how to remove and replace cartridge. If this fixes your problem please rate this as fixed. If you need more help just ask.Thanks.
http://files.support.epson.com/pdf/sc42ux/sc42uxu1.pdf
Posted on Apr 06, 2008
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
Epsn C42 No Yellow
The ink path is probably plugged. Try getting some ink cleaner and a squeeze bulb to purge the path IN the printer by forcing cleaning fluid into the yellow channel (cartridge removed). After it flows, it will likely take a bit to get the yellow flowing. If you have a refill kit, you could "encourage" the flow with it. Nothing you can fix by cartridge, the problem is in the printhead.
Aug 21, 2009 | Epson Stylus C42UX InkJet Printer
Printer will print with almost no ink on page in colour or b/w
You have to have both the cartridge installed and then
Run a nozzle check to make sure the nozzles are clean. Try running a printer self-test to make sure the printer is running properly without using the computer.
Macintosh 9.x or earlier: Open the File menu and choose Print. Click the Ink icon. You'll see a window showing the ink remaining in each cartridge.
Macintosh OS X: Double-click the Applications folder on your hard drive. Double-click EPSON Printer Utility, select the C42 Series printer in the Printer List window and click OK. Then click the EPSON StatusMonitor button. You'll see a window showing the ink remaining in each cartridge
May 04, 2009 | Epson Stylus C42UX InkJet Printer
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My Epson SX 100 is low on the three colours but when I open the top to get to the Cartridge Bay, the cartridges are not stopped on the right place for me to change them with new ones. They are stopped on...
Have you pressed the ink button to move the ink carriage to the correct position? Press the ink button to indicate each empty cartridge and then move it into the replacement position.
If it doesnt move you could always turn the printer on and as the carriage moves across pull out the cable or switch off at the wall socket. The carriage can now be pushed into the correct position. Push it back fully to the right before turning back on.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus C42 plus
this is for windows xp
start-settings-printers n faxes(click on it)-right click on your printer name - click on properties(below)-printer properties dialog box-click on service.click on the appropriate service.
Apr 03, 2008 | Epson Stylus C60 InkJet Printer
EPSON STYLUS C42UX PRINTER.
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
To make my Epson printer, model "Epson stylus C42UX" work in India, with Indian ink catridges T038 & T039
This is a tricky one, but there are possibilities.
1. Buy a set of epson C42 cartridges from the cheapest source and keep refilling them - you will need a (very cheap) resetter.
2. Transfer the C42 chip to the C41 cartridge - they are only clipped in place. I don't know if this will work because I only have knowledge of C42 cartridges - the C41 cartridges may be keyed so they wont fit in a C42 cartridge carrier. You may be able to identify a clone manufacturer for which this is possible. You will also need the resetter for this solution.
3. Fit a Continuous ink system (CISS) see for example http://svp.co.uk/products-solo.php?pid=3569&prepg=1
Nov 06, 2007 | Epson Stylus C42+ InkJet Printer
65 people viewed this question
jasbo
jasbo
