Question about HP Pavilion F1903 19" Flat Panel LCD Monitor
Monitor going black
A couple of weeks ago I started having a problem with my monitor F1703. I would move the mouse and the screen would go blank. I rebooted several times and it finally stopped. Last night the screen will not stay on - it keep going black and if I turn the monitor off and then back on I get my screen - dark for about 3 second and then goes black. Any suggestions as to what the problem is? monitor goes black after a couple seconds after i turn on.
  • 472 Answers
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Posted on Apr 09, 2008
Monitor going black
may you just uninstall the first video card driver & monitor driver, & then install it again..
please post back & let us know here, how things done..
Thank you
May 02, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Just moved and trying to set up the computer. Monitor light keeps flashing with a blank screen
Check that the "data" cable between the monitor and your computer's video-card is tightly connected at both ends.
No "signal" reaching the monitor means nothing on the screen.
Sep 26, 2010 | HP Pavilion F1703 17" LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
The hp f1703 will display for 3-5 seconds and go balck
rking3905, Please tell me if F1703 is BOTH BLACK and BLANK, or if it is just BLACK! If the screen is BLACK and you can see the WIN-desktop with aid of flashlight held 1" from the screen then the monitor's "switch-mode-power-supply" is in partial shutdown mode having detected a FAULT condition with the "cold-cathode-fluorescent-lamp" power supply called an INVERTER circuit (12vdc to 600-1200vac) to light-up the lamps hung on the rear of the LCD panel which produce WHITE light so you can see the image or text displayed on the LCD glass panel. In any case, you or a technician will need to evaluate the true state of your monitor. Also try to view some video clips on YOUTUBE that deal with "LCD monitor disassembly" and "LCD monitor repair". The longer (8-12min) clips are best. FYI goto www.ccl-la.com/badcaps, www.lcdparts.com, www.badcaps.net for more information on what may be the cause of your BLACK and or BLANK screen! If this was of some help, please rate this response on fixya.
12fixlouie
Nov 05, 2009 | HP Pavilion F1703 17" LCD Monitor
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor screen is black when hooked up to my laptop.
u have to set screen resolution of monitor to 1024 *768
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1903 19" Flat Panel LCD Monitor Logo
303 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
