Question about Whirlpool Calypso GVW9959K Top Load Washer
How to Open up a Kenmore Elite Calypso Wash Motion Washer
I'm trying to figure out how to open up the washer to check for a leak. Someone said to look for the screw under a mediallion but there is no mediallion anywhere on the washer.
Can someone familiar with this washer help??
  • 5,911 Answers
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
Posted on Apr 06, 2008
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
I GET THE FL DISPLY ON MY KENMORE ELITE CALYPSO WASH MOTION. HOW CAN I REMOVE THAT SO IT CAN START WORKING AGAIN
unplug your washer for 5 minutes and try it...these washers are known to have pump issues..if its older one..the pump can be replaced...if its newer..the motor/ pump has to be bought and replaced...
Jan 22, 2011 | Kenmore Washing Machines
How to Open up a Kenmore Elite Calypso Wash Motion Washer: I opened up the lid but how do I release the the snaps that hold the inside machine to the outside...?? I have a lot of "sludge"...
Just checked the service manual on this model. To open top, first UNPLUG the cord, then gently pry off the emblem from the front trim. Behind it is a T-20 torx screw, remove it and then you can pull the entire top toward you, the front, about half an inch or so to clear the latch and lift the entire top. It's hinged at the back. Ensure you have enough room behind the machine for the console to clear and prop the lid up. If machine is still under warranty, I wouldn't recommend self service, if not, have at it, all you can do is save yourself some money!
Hope this helps
kcomp1863
Jan 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washer leaking
On the front of the machine there is a oval shaped medallion that says 'whirlpool' - pop that out and remove the screw. Next, on the sides about two inches back from the front there are two posts that help hold the top on - use a wide screw driver or putty knife to pry the top up. Once the post disengage it's a easy sailing, sort of.
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
3,109 people viewed this question
Dan Webster
Dan Webster
Sal De
