Mazda Master
- Posted on May 24, 2010
Re: Where is the fuel filter on a 2000 Mazda Millenia 2.3...
Fuel Pump-Mounted Filter
Before servicing the vehicle, refer to the precautions in the beginning of this section.
Properly relieve the fuel system pressure.
Remove or disconnect the following:
Negative battery cable
Fuel pump cover plate
Fuel lines from the fuel pump
Raise the fuel pump from the tank.
Remove the fuel filter assembly.
To install:
Install or connect the following:
Fuel filter to the fuel pump. Lower the pump assembly into position
Fuel lines
Start the vehicle, check for leaks and repair if necessary.
Install the fuel pump cover plate.
Inline Filter
Exploded view of an in line fuel filter and related components
Air intake hose and/or filter housing, if necessary
Fuel line clamps, if equipped
Fuel lines from the filter and plug the openings
Filter clamp bolt/nut by loosening them.
Fuel filter from its mounting bracket
NOTE
Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position.
To install:
Fuel filter in its mounting bracket, making sure the flow arrow is pointing in the proper direction
Fuel lines to the fuel filter
Air intake hose and/or filter housing, if removed
Pressurize the fuel system and check all connections for leaks.
