Question about Belkin (F5D7231-4) Wireless Router
Mbps speed should be 125 mbps, but when I check the properties it says 54 mbps...is this correct.
  • mick350 Apr 06, 2008
    It is a Belkin G+ router from Argos.The specification in the catalogue states 125mbps. On the box it says "This device achieves an actual throughput of 34.1Mbps which is the equivalent throughput of a system following 802.11g protocol and operating at a signalling rate of 125Mbps"
  • Anonymous May 11, 2010
    mick350,
    is 125mbps is indicated at the box of ur router when u purchased it?,
    Sergeant:
    Champion:
  • 427 Answers
Sometimes when this happens is because a port may need to be forwarded.Try that, but if the problem continues, it would effect you severely. Your internet will have the same speed, but your downloads will be half the speed. (Still Fast thoug)
Posted on Apr 19, 2008
  • Anonymous Apr 20, 2008
    that would i put in my last comment was supposed to be a wouldnt. Anyway, your hardwired computer is the one recieving the 125 MPS. All other wireless devices will still get 54MPS no matter what. (im pretty sure.)
6ya staff
SOURCE:
I increased my internet service from 50 to 100 Mbps, but the properties for the Thomson TG587 v7 reflect only 54 Mbps. What do I do to get the full 100 Mbps?
the bandwidth that connects might not allow or be capable of any more mbs per second or the network is overloaded you can test your bandwidth just click on the link
you could try to speed up your bandwidth im not sure how it works or if its worth it
hope this helps
http://www.bandwidthplace.com/
Jul 28, 2011 | Computers & Internet
NetGear wireless router WGR614 v6 runs with speed 1 0 mbps instead of 54 mbps
how far away are you from your wireless router when your getting 10 mbps?
Please note that wireless will not guarantee speeds of 54 mbps.
It will dramatically decrease the farther away you or how much interference there is between your laptop and router.
Also check if your wireless router is set to 802.11 G mode. if you have any devices that only support 802.11B you will only get speeds up to 11mbps compared to G at 54mbps
Mar 13, 2011 | Computers & Internet
The wifi is going 54 mbps but should be 100 mbps all cords are plugged-in properly what do i do?
wireless speed depends upon the wireless card that is installed on your computer...
if your computer have a
802.11 b/g card, it will connect at 54 mbps speed (That is the maximum speed at which the wireless can connect to the router)...
802.11 n card, it will connect at 150+ mbps speed...
Feb 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Hi, Although I have N series ADSL2+ Router and a N
N series routers can communicate at a speed of 150 Mbps, only if the wireless adapter that is built-in into the computer comes under N standard...
Most of the wireless adapters comes under G standard, which can communicate only at a speed of 54 Mbps...
The N standard routers are backward compatible, which can communicate with N standard adapters at 150 Mbps, and with G standard adapters at 54 Mbps and with B standard at 11 Mbps...
The speed in which the adapters can communicate are listed below...
B - 11 Mbps
G - 54 mbps
N - 150 Mbps
Dec 23, 2010 | Computers & Internet
100mbps on my house computer but only 54 on my laptop
100mbps is just the maximum speed capacity that can be used and depends on the speed that you subscribed so it doesn't mean you'll get a sharp 100 mbps on that.
Mar 31, 2010 | Toshiba Satellite M55-S331 Notebook
Slow internet at 120 Kbps but fast connection at 54 Mbps Why
54 Mbps is the speed between your computer and your wireless router. The .8 Mbps is the speed of your connection between the router and the internet. You should call your ISP and ask what your speeds should be; there could be something wrong on their end or your modem might be malfunctioning. It's also possible that your WiFi connection itself has a weak signal. That can be corrected by moving the router and the computer closer together, or getting a signal relay and putting it between them.
Jan 22, 2010 | IBM Computers & Internet
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Connection problem
It sounds as if either the router is not set at enable DHCP which gives your pc's wireless adapters an automatic assigned ip address, so check in the routers settings via your web browser normally by typing 192.168.2.1 and check that DHCP is enabled and look in the menus and see if the transfer speed is set correctly at 54 mbps, the same as your wireless adapters. Also go to your wireless network adapters in network connections in control panel, right click on your wireless connection icon and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok it and close window. The problem with 'pre n' routers is that this setup was released before the alloted 'N' type transfer speeds and required firmware, hence named 'pre n' and can be quite troublesome at times. If you go through the above proceedure they should all connect, but you must also check in my computer, right click then click properties and look at the computer name tab and check that all the pc's are set at the same workgroup name, normally 'workgroup' or 'mshome', otherwise each pc will not be able to see each other.
Jul 05, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
Router down when copy files
Check in your routers settings via your browser that the file transfer speed is no higher than 54 mbps, as it may be set at 108 mbps or 125 mbps as a 'g' type router should be, but your wireless network adapters can only work at 54 mbps and are crashing the transfers.
Feb 28, 2007 | Belkin (F5D5231-4) Router
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
