Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No carpet cleaner coming through
Hello there, I am having a problem with the cleaning solution remaining in the solution vessel. The cleaner is therefore only washing with water. It is set for the cleaning solution to come through. I would be grateful for any answers to this.
  • 25 Answers
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Posted on Apr 14, 2008
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Vax customer support
It is unclear as to whether you have a vacuum cleaner or a carpet
cleaner. When there is no more give you have stretched the hose
to the MAX. Vacuums and carpet cleaners come with stair tools.
If for some reason you do not have these go to a local vacuum
store and tell them what you have and ask them what you may need.
Regards,
Dennis
Aug 19, 2014 | Vacuums
Why is thecleaner not coming out of carpet cleaner
You have to continually hold the trigger to release the cleaning solution. If you don't hold the trigger closed then you are running the vacuum in carpet drying mode. http://hoover.com/file/610/
May 25, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
How to clean spots off carpet
It depends on what the spots. They may actually be stains. Spots will come out if you use the correct cleaning process and cleaners but stains are permanent unless bleached or dyed. If you are not sure it may be less expensive to call a professional carpet cleaner that knows what they are doing (not all of them do)
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
77 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
