Relatd to slow working
Whrn the computer is started it's works very slowly.
When a disc is inserted in the CD-ROM it is not read.
  • 106 Answers
These are two different problems...
1. most likely you have loaded too many programmes in the startup...uninstall the unwanted programmes...and clean the registry by registry cleaner.... clean your c drive or the drive in which OS is loaded by system tool...disc cleanup (in accessories)
2. increase your RAM if you still want to use all the programmes you have loaded.
3. Use a cd rom cleaner disc to see it the rom stars reading...or else you will have to replace the CD Rom
Posted on Apr 06, 2008
SOURCE:
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
CD-Rom not reading cd's
it sounds like the cd rom driver in windows is not installed correctly try reinstalling the cd rom if that does not work the cd rom needs replaced
Sep 02, 2009 | Dell Dimension 4500S PC Desktop
DVD R/W doesn't read the disc
Hello my friend, try to insert another brand new disk with no scratch to test if its still work. If it is not then try to ship back the device to its supplier or find technician in your place to assist you in order to check if that device is still working. Sometimes the laser eye of the DVD ROM is something to do with that. also try to  clean your DVD ROM if you have disk cleaner.  Hope thisadvice helps you. Just contact me if you need more assistance. Just reply to thispost. Thank you
Jun 17, 2009 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
My laptop cd/dvd can't read disc when inserted
may be your cd/dvd rom is weak. replace the dvd rom.
Jan 25, 2009 | EA Sports Tiger Woods PGA Tour 07 for...
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Samsung sh-s182 not read cd's and dvd's
So you mean each time you insert the disc it ejects automatically?or you have a problem reading with the disc?
May 09, 2008 | Computers & Internet
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
Open Questions:
Inferior security for FIXYA, 6YA, Verticalscope, and Torstar web sites reported repeatedly due to cybercriminals like the Indian spammers who have taken charge here. Inferior security at FIXYA and 6YA leave your financial and bankcard data and personal passwords at risk of being sold by cybercriminals in India. Toronto-based VerticalScope Inc. says six of the community websites it administers were hacked last month in the latest of a recent series of data breaches affecting Canadian online user information. The company says in an emailed statement an “unauthorized party” gained access to community member data for six of its websites on Oct. 17 and 21 and some of the data was disclosed online. It says the data did not include credit card or banking information but did include usernames, email addresses, encrypted passwords, user identifications, registration dates and IP addresses for websites including DIYchatroom com, PBnation com, HysterSisters com, ToyotaNation com, JeepForum com and WatchUSeek com. Alex Holden of Hold Security, LLC, says his American cybersecurity firm was able to intercept hackers’ attempts to sell data stolen from VerticalScope and tracked down screenshots containing current secure information to confirm the breaches had taken place. He says the attack was “rather sophomoric” and its success doesn’t reflect well on VerticalScope’s cybersecurity readiness, adding it’s unclear how many people had their confidential information stolen. VerticalScope, which is majority owned by TorStar Corp., says it has caused all of the passwords on the sites to expire and has notified affected users. It says the breach has been reported to the federal Privacy Commissioner, Toronto Police Service and the RCMP cybercrime unit. About 8,000 Canadians had personal information and, in some cases, credit card information, exposed in the massive Equifax cyberbreach that occurred in July but wasn’t reported until September.
Oct 14, 2019 | Dell Computers & Internet
Computers & Internet Logo
66 people viewed this question
Ekse
Alun Cox
