Question about Celestron NexStar 130 SLT (306 x 130mm) Telescope
GoTo Problem Please Help... im and going crazy!!! I have a Celestron Nextstar SLT 130 GoTo scope and love the pictures it produces but cant get it to GoTo very well. It dose the three star alignment, 1 star alignment and solar alignment fine and have no problems with alignment, level the scope well and set the time to nearly the second. Once aligned and i start to move the scope around the night sky, if i try to ask the socpe to slew back to a star, even an alignment satr, it goes in the general direction but doesn't bring the star into the view field and is off by a significant amount. I have tried centering the star in the view and then asking the scope to find that star and it goes out of the view by the same amount every time. Im goging crazy. I thought it was a motor problem and swaped the scope at the store but the new one is exactly the same. I just dont know what is wrong. Im in the southern skies and only reviews is for the northern, dont know if this matters. Any help would be fantastic. Just cant get it to slew to any objests correctly!
    Genius:
  • 1,027 Answers
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Posted on Apr 18, 2009
SOURCE:
How do I allign it?
Use the finder scope to locate the object in question, then main scope will be aligned for magnified viewing.
May 08, 2016 | Celestron NexStar 130 SLT (306 x 130mm)...
Problem viewing planets using 25mm eye piece. which eye piece works the best? nextstar 80 slt
The smaller the number on the eyepiece the greater the magnification-- the maximum magnification of any telescope is about 50 times aperture. You scope is about 3 inches -- so 150 power is the maximum usable magnification.
BUT-- only under perfect conditions -- perfect sky-- perfect optics -- perfect eyepieces. Usually 30-40 times aperture is all you will get on a typical night with some turbulence in the atmosphere.
Read my tips on my profile page and listen to my podcasts at :
www.telescopeman.us
May 13, 2011 | Celestron NexStar 80 SLT Telescopes 22086...
Looking for a replacement focuser for a Celestron NexStar 130 SLT.Would like it to be 1.25 with 2in capibilty with fine focus dial
Either contact Celestron directly-- or look here--
http://www.telescope.com/control/accessories/telescope-focusers
Feb 13, 2011 | Celestron NexStar 130 SLT (306 x 130mm)...
Ihave bought Nextstar SE4. I aligns and moves but i cant seeanything from the eyepiece. In day light i can see brightwite background but no image. Please help
Put the eyepiece with the largest number written on it into the focuser. This is your lowest magnification.
During the day time point the scope at a distant object and practice focusing -- you may need to turn the focus knob several times right or left to achieve focus.
It will focus if you turn the knob enough.
Jan 14, 2011 | Celestron Optics
Just got a celestron nextstar 5
You are NOT in focus. You are seeing the central obstruction in the lens on the front of the tube. Put the eyepiece with the largest number written on it into the telescope. Go outside during the daytime and practice focusing on a distant object.
Once you are focused properly you can see the obstruction.
Read my GOTO scope TIps on my profile page.
Apr 07, 2010 | Celestron NexStar 5 SE (300 x 44.45mm)...
NexStar 130SLT won't keep time when powered off. Is there an upgrade?
No, most scopes do not have built in GPS or a built in clock. It's normal to have to set, TIME, and DATE in the hand controller.
My Meade LX90 has a built in clock, it's an exception to the general rule. Most GPS computer GOTO scopes do not keep time-- you must wait a few minutes until the GPS acquires enough satellites to get the correct time, date, and location.
Dec 29, 2009 | Celestron NexStar 130 SLT (306 x 130mm)...
Celestron NextStar 80 GTL hand held problem, tried to
You obviously burned out something inside. Many of these scopes require a proprietary style 12 volt plug with the correct polarity ---
My only suggestion would be to contact celestron and send it in for repair.
http://www.astronomics.com/main/Warranties.asp/catalog_name/Astronomics/category_name/AK9TFU21GCR78LKGXH66AS3XN7/Page/1
Jul 05, 2009 | Celestron Optics
Not seeing
The city lights will not hamper planetary viewing. Excessive power is a common mis-conception. Use 80x or so for best viewing. That would be about a 4mm eyepiece. Start with lower powers and work upwards in easy steps. The greater the power, the narrower the field of view, and it becomes very hard to find anything at all.
Apr 18, 2009 | Celestron NexStar 130 SLT (306 x 130mm)...
Celestron NexStar 130 SLT (306 x 130mm) Telescope Logo
352 people viewed this question
Top Celestron Optics Experts
Ekse
Bob Peloquin
Level 1 Expert
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
