Question about Vtech 9009111 Cordless Phone
Vtech 9127, display bad
My vtech 900mhz cordless phone {model number 9127}, the display is weird, when ever i type in a number or someone calls, etc; the charecters look choppy, and the number eight looks like a backwards 3...whenever i hit it, it does get a little better, but i dont wanna break it.
  • pagan954 May 15, 2008
    characters display dim and choppy
  • Anonymous Mar 29, 2014
    Number of rings
My vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too Thank you
Posted on Jul 30, 2008
SOURCE:
How to unblock a number on vtech cordless phone
see these links
Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support/product/3394
Press VOLUME? until you see Call Block, then press MENU/SELECT. Press VOLUME? until you see Calls w/o num, then press MENU/SELECT. Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
How to unblock a number on your VTech cordless phone - Fixya
www.fixya.com/support/t26508052-unblock_number_vtech_cordless_phone Mar 4, 2017 - my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time ... How can I unblock a number on my vetch phone. It ...
Mar. 11, 2018
SOLVED: How to unblock a Vtech cordless phone ...
Sep. 12, 2017
How do i unblock numbers from a vtech phone ...
Jan. 19, 2015
Vtech DECT 6.0 Digital Cordless Phone Unblock ...
Aug. 3, 2014
More results from www.fixya.com
unblock number on vtech cordless phone Google Search
Jun 11, 2018 | Vtech Lands Phones
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How do I get my messages from my Vtech 6.0 phone? What numbers do I call, etc.
With the normal type of home phone you have to contact your phone service provider. There is a monthly fee for voicemail. They will tell you the number you have to phone which is usually a 4 digit number like 1471, then you put in your pin code and pound # key and press 1 to get new messages.
The category of VTech phone you have posted to has an inbuilt answering system. If that is the phone you have, give me the exact make and model, and I will find the manual and let you know what you have to do. Post as a COMMENT under my post. Then I will get a notification.
Oct 10, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i check my voice mall on my Vtech phone Model number CS6114
The CS6114 isn't a voicemail system. You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 10, 2012 | VTech Communications CS6114 - cordless...
My vtech digital 6.0 cordless phone says not registered but when someone calles the base of the phone still rings and people are able to leave messages but the actual phone isnt ringing, how can i fix it?
The base and the handset are not communicating. To have them do so, you need to "register" the handset with the base. Since you neglected to specify the model of your VTech DECT 6.0 phone I can't tell you how to do that. I can suggest you enter the model number into the search box here to download a copy of the manual. The manual will give you instructions on how to register the handset.
Jun 22, 2012 | Vtech DECT 6.0 Digital Cordless Phone
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
Have a 900mhz cordless phone how do i change the message on answering machine
Since you declined to specify the model of your VTech system, I can only direct you to enter it into the search box here to download a copy of the manual.
Jan 25, 2011 | Vtech Lands Phones
I have a UNiden 900mhz extended range and lost the guide for resetting modes, time, number of rings, etc. Can you give me a quick guideline?
just look up online Uniden cordless phone Owner's Manual 2.4Ghz model EXAI 2224 series. It's free and lists all the commands needed for your Uniden 900mhz phone. page 1 to 68 just like the same one that came with the phone.
Sep 05, 2009 | Uniden Cordless Phone exai398i
Vtech 9009111 Cordless Phone Logo
541 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
