Question about JVC GR-D20EK Camcorder
Camera on charge
My camera wont work unless it is on charge, if I take it off the camera will switch off. It doesn't work all the time even when it is on charge. Sometimes when I switch it on it says condensation operation paused please wait. What is going on with my camera?
  • 34 Answers
You may have more than one problem.The battery may not be charging,which is a power supply problem,secondly the loading motor is not fuctioning due to connection problems to the servo pcb.
Posted on Sep 05, 2008
Camera does not start even with new batteries
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Feb 13, 2014 | Konica Minolta DiMAGE Z5 Digital Camera
Charge fujifilm finepix f410
contact fuji customer service they are great
Oct 11, 2017 | Cameras
My camera wont work unless it is plugged i even thouh its fully charged
Sill I would check the quality of your batteries. If you have a multimeter, you can do it yourself. My Kodak KLIC-5001 batteries, I bought in 2005 are still working. Three months ago I charged them the last time and the now still give more than 4,0 Volt. The print on the batteries is 3,7 volt. So if your battery is only just under 3,7 volt, but I think it will be more than one volt below, after they just have been charged, the are no good at all. If you don't have a multimeter, ask the people you know if someone has one. Also check is everything in de camera is clean and shiny and no debris is in the battery compartment. Check this with a magnifying glass, because the smallest spec of dust cab be a culprit when right on one of the contacts.
Nov 22, 2013 | Kodak EasyShare M575 Digital Camera
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My camera wont charge, when i plug in the camera the green light will blink several time and then disapear
It's probably a worn out battery. The batteries are good for 150-300 charges. Every connect is a charge. Doesn't take long.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
Do you leave camera on as it is charging through computer for the Kodak Easyshare M753 Camera?
Hi it dont need to be on whilst charging, some cameras will switch themselves on when you plug them into the computer, but you can still turn it off, now you need to bare in mind that unless you are using a powered usb port is one that plugs into the mains then into your computer you may have problems charging the camera enough through the computers own usb port, it may still charge so you will have to try some cameras will just power up enough to enable you to transfer pictures onto your computer.
give it a try and see how you get on, it wont matter if the camera is on or off whilst plugged into computer how ever it will charge quicker with the camera off if it will even charge at all
Jul 17, 2010 | Kodak Easyshare M753 Digital Camera
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
Hello
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 02, 2010 | Kodak EASYSHARE M1063 Digital Camera
Wont come on even when a new battery is installed.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
JVC GR-D20EK Camcorder Logo
113 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
