Question about GE Spectra JBP78 Electric Kitchen Range
Cooktop burner doesn't switch between small and large
Hello - I have a GE JBP78W oven/cooktop with one burner that can switch between a small or large size functioning burner. I cannot get the burner to operate as a large burner after switching to the large size.
  • Tonylube Apr 11, 2008
    Hi Ginko,
    I want to make sure I understand what you're suggesting. You say switch or part #3 may be the culprit. The switch I'm referring to is part #33. The dial/switch associated with the burner works; it admits power to the element, but only 6" of the total 9" of teh element heat up, which would represent the "LO" setting of the toggle switch labeled #33. My issue is when i toggle to "HI", the entire 9" element does not heat up. Only the inside 6" heats up. Another response I recieve from Fixya said the element wasn't working that needed replacing. What do you think based on the additional detail above? Thanks.
  • Tonylube Apr 27, 2008
    The problem was fixed by replacing the heating element (not the switch).
  • GE Master
  • 19,396 Answers
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch.
The switch for your appliance has part number:
WB21X5243
You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace.
Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
Regards
Posted on Apr 07, 2008
  • 796 Answers
Are you saying that the flame is doesn't get big.??
Posted on Apr 06, 2008
    Sergeant:
    Champion:
  • 306 Answers
The switch in the oven needs replaced
  • 1 more comment
  • cory casper
    cory casper Apr 11, 2008
    Like I said, the switch needs replaced
  • cory casper
    WB21X5243
  • cory casper
    cory casper Apr 27, 2008
    based on the info you gave the answer was right.
JP350.. Large burner (front right) only the inner circle lights up no matter where the switch is set (large or small). Bill wjgibbon@syr.edu
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ewrwer
werwer
Dec 23, 2010 | GE 30 in. Profile JP350 Electric Cooktop
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
GE Spectra JBP78 Electric Kitchen Range Logo
293 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
