·Remove any hardware you may have installed prior to you having the problem, chech that the video card is fully in the slot if you have one ·remove the ram and clean the gold edges both sides, with rubbing alcohol or a pencil eraser, ·and re-insert them, (not an ink eraser as it will do damage) ·swap them around if you have more than one, try one at a time. ·if you only have one, borrow one from a friend or try the ram in your friends pc, if that's possible, ·or take the ram to your local pc shop and ask them to check it for you (they may do that for you) ·if you can establish that the ram is ok, it is most likely, that the motherboard has failed . ·Generally a dead hard drive would not stop the PC from posting. good luck with that please rate my efforts. Terry
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend...
(More)
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend ?
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
i can not find or install my streamci.dll file i need this file for sound. i had it up until about 3...
(More)
i can not find or install my streamci.dll file i need this file for sound. i had it up until about 3 wks ago. then i did a reformat now i have no sound at all. says this is the missing file. i found it, but it is read only. help please. thank you sheila
need to download ageia physx driver ver 2,8.1 to run game everytime i try to launch the game it says...
(More)
need to download ageia physx driver ver 2,8.1 to run game everytime i try to launch the game it says install latest ageia physx drivers ver.2.8.1
wont do anything after'start safe mode,last good config,start normally screen,seems like its gona...
(More)
wont do anything after'start safe mode,last good config,start normally screen,seems like its gona boot then sez press F1 to setup,goes to bios{i dont no if thats set rite now as iv changed various settings}then the screen makes a couple of clicking sounds then goes to start safe mode,normally etc.
