Question about Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N)
Speakers disabled!!?? help please
I was trying to connect some external speakers to my thinkpad R61i and was having trouble so i disabled the internal speakers and now i cant get them back again. it says no drivers are installed for this device. do i have to find sofware online to reinstall them, please help. thanks.
  • 123 Answers
Jake carson,
ol u hve to do is enable the one that u have disabled..
and thus ur external speakers when u installed it,does any prompt info pop up onto ur screen?.\,asking for drivers??
Posted on Apr 06, 2008
SOURCE:
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
Internal microphone works fine; I need to use an external. How to enable external and disable internal?
you need to go to the speaker icon bottom right corner and right click and select adjust audio properties. Then select voice and the drop down menu with voice recording you select your branded external mic.
Enjoy
How many ram bank is available in IBM lenovo thinkpad R61i model laptop?
Click here for the ram specs on the R61. Click here for the ones on the R61i. This should have all of the information you need. Please rate =]
Mar 04, 2011 | Dynamic 2GB RAM Memory Upgrade for the IBM...
The speakers of my lenovo R61i laptop have stoopped working
Welcome to FixYa!
What do you mean it stopped working? No sound at all?
Please try the following:
1. Please make sure the sound is not set to mute. Try to adjust the sound volume.
2. Reinstall the audio driver. You can do this using the drivers disc that came with the computer or you can download the audio driver from the computer manufacturer's website: http://support.lenovo.com.
3. Try to connect an external speakers or headset. If you can hear sound on an external speakers or headset then the internal speakers of your laptop is already defective.
Hope that helps. Thank you for using FixYa!
Feb 14, 2011 | Lenovo ThinkPad R61i Notebook - 7732B4U
Output from my thinkpad x40 is balanced (left-right) through the built-in speakers, but only the left channel can be heard when external speakers are plugged in.
As you said your internal speakers are OK, then may be the problem with the external speaker. Check with another set of external speaker. if works fine then check your previous external speakers connection. if still no sound the neeed to check the motherboard.
Aug 21, 2010 | IBM ThinkPad X40 Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
How to connect AT&T Laptop/Connect PC Card?
looking at the specs for your Thinkpad i believe you can connect your AT&T PC card since it has a Type II interface
Apr 11, 2009 | Lenovo ThinkPad R61i Notebook
Disable the fingerprint sensor on lenovo R61i
If you don't plan on using it anytime soon the easiest way is to just remove the software from the ADD / Remove Programs section in the Control Panel.
Let me know if you have any problems.
Mar 04, 2009 | Lenovo ThinkPad R61i Notebook
How you did the disabled, same way you can make enable.
Ok first make a check whether you required a driver or not. Follow these steps:
  1. Goto control Panel
  2. Double click on System Icon
  3. Then Click on Hardware tab
  4. Click on Device Manager.
It will open the device manager window. In this window see carfully, if there is any component with yellow marked icon, then you have some missing driver, means you have to re-install the drive. If there is any component with Red marked icon then you have disabled this, means you have to make it enable for work. Just right click on that red icon and select Enable from the pop-up appeared.
And to re-install driver goto your manufacturer site put model no. and make search, they will give you the link for download.
If any problem just Ask me.
Thanks
Iqbal
Apr 06, 2008 | Computers & Internet
Open Questions:
See all Lenovo ThinkPad R60 with Wireless Wide Area Questions
Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Logo
98 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
