I have a Briggs and Stratton 2200 pressure washer with a 4.5 engine and I can't keep it running, you prime it and it runs for a couple seconds and stalls. It stayed running a couple times idling rough but it stalled as soon as I tried spraying the pressure washer.
Engine code is: 1 OH902 / 0113E1.
I checked the air cleaner (seems clean) and primer (squirts fine) and cleaned the plug. Unit is not run very much. This is the first time I have tried to start it this year and no I didn't drain the gas last year, I never had an issue in prior years. I remove the tank and carb to look at the float but couldn't find a float.
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
