Question about Microwave Ovens
LG microwave no longer heats!
My LG LRM1260SW microwave no longer heats since I tried using the kitchen timer function yesterday. I'm afraid I didn't use the timer function properly as the oven felt hot afterwards.
What's the solution?
  • Microwave Ovens Master
  • 9,098 Answers
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Posted on Apr 08, 2008
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
Need a manual for a Lg microwave oven model LRM1260SW
No! there is no reset, the problem is caused by one or more door swiches that have become defective, or the keypad control board a possibility.
Apr 14, 2012 | LG LRM1260SW Microwave Oven
The heating element went out (runs but no heat). Am looking to replace the microwave since its not that old but I don't have the receipt.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,.//';
Jul 10, 2011 | LG LRM1260SW Microwave Oven
I have LG MS3447GR Micro Wave Oven. It is functioning as before without heating. Please help?
heatman101 ,.,./ll
l
Mar 16, 2011 | LG LRM1260SW Microwave Oven
My lg Microwave Model no. LRM1260SW is not working. It's inside light is ok but it is not warming/heating anything.
heatman101
Jun 16, 2010 | LG LRM1260SW Microwave Oven
Turns on but doesn't heat only a year old LG LRM1260SW 1200 Watts Microwave Oven
I have had the LG model lrm1260sw microwave for 3 years. Recently it quit heating. I found the problem was the soldered grounding lug connection on the power transformer had lost circuit continuity and failed. One of the secondary coils on the power transformer, red wire / bare copper wire, is connected to ground / chassis. I cleaned the lug connection and added a length of wire twisted together with the bare copper coil wire and soldered to the grounding lug. I then grounded the extra added length of wire to another chassis ground point. Make sure the transformer to chassis mounting screws are tight also. Now the microwave oven works like new again.
Feb 27, 2010 | LG LRM1260SW Microwave Oven
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
Not heating. all else works. any experience with warranty-- do they pay for labor or just the magnetron? if so can I fairly easily replace it myself? Thank You
Oct 18, 2009 | Goldstar MV-1615 Microwave Oven
It is running, but doesn't heat the food.
I had the same thing happen to my microwave and the Magnatron was the bad part. There are some things that you can check and I would be glad to help. I bought the parts for around $70.00, but mine was a built in unit.
Let me know, I will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 21, 2009 | Goldstar Microwave Ovens
Microwave Ovens Logo
604 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
