Question about Canon PowerShot S30 Digital Camera
My display doesn't work, is there a setting issue
I have a 2007 Mazda 3, that currently has a A/C problem and radio problem. The radio still has it’s manufacture display. When the car is turned on, the radio display is blank. But if you were to, rotate...
This might be a CAN Bus communication error (controller area network) There are 2 CAN Bus control modules - a high speed module to interface with the ECU and driving inputs/outputs and a medium speed module to handle the displays and driver data records (trip, fuel economy and consumption etc) The medium speed module does things like radio and A/C interfacing. The headlight is a mystery. Plugging in a diagnostic tool will test the CAN Bus interfaces for communication errors.
Sep 28, 2018 | Mazda Cars & Trucks
Why is everything i look at inverted?
If everything is inverted, you may have the display orientation set for Landscape/Portrait (flipped). In this case, the taskbar will be at the top of the screen. With most Windows OS versions, click on the desktop (anywhere with no icons or running programs) and select Screen Resolution. In the drop down menu for Orientation, change the setting. (Landscape is usually the desired choice for computers with Widescreen displays.)
With some laptops, you may find this under Display Properties or Graphics Options. (On my desktop, changing the Graphics Option is available but doesn't work.)
I hope this helps.
Sep 15, 2012 | Computers & Internet
Ge JES0738 LED display is fine but turntable doesn't work, microwave doesn't start. Is it a fuse issue?
No! from the description it is one of the door switches that has become defective. The solution, all the door switches need to be tested to find the bad one.
Jun 13, 2012 | GE Microwave Ovens
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 08, 2011 | Computers & Internet
Hi I have an Issue with my display on dell inspiron 14R. It doesn't display in the laptop but when I connect it to the external systems with HDMA cable it works. how to resolve this issue.
Click FN+F6 or F7 (whichever has the monitor icon on the F# Keys).
This would toggle the view between your computer and the external display.
Thanks
Please Rate.
Jul 07, 2011 | Dell Inspiron N4010 Notebook
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
Canon PowerShot S30 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
