I have a hp m9150f pc and a sony wega sdtv, installed a s-viedo wire. need step by step instructions how to program, windows media center says set up tv signal, nothing I do seems to work. can you help me please
  • 13,433 Answers
Step by step how to enable svideo / tv on your nvidia videocard
Preparing the graphics card for TV Output.
The first step in configuring your graphics card for TV output is to first identify what type of tv output connection is available on your NVIDIA based graphics card. The video output jacks are located on the backside of the video cards mounting bracket. Once you have identified the TV out jack on your graphics card, check that your TV features the same type of video input. If your graphics card only has an S-Video jack for TV out but your TV only has composite inputs, then you may still connect your graphics card to the TV using an S-Video to composite adaptor. Aftermarket S-Video to composite adaptors can be purchased from major electronics retail stores or online. To get the best quality picture on your TV, do not use a cable longer than 12ft. in between your graphics card and TV. Check that you have connected the graphics card directly to your TV. If there is another device in between your TV and the graphics card (such as a VCR, switch box, satellite dish, receiver etc.) it will interfere with the graphic card's ability to properly detect the presence of your TV. This will result in the inability to select your TV as an output device from within Windows. To prevent this, please ensure that the graphics card is connected directly to your TV. After you have connected the appropriate cable from graphics card’s TV output to your TV's video input, you may turn on your PC.
Enabling TV Out
Once you have verified all the connections are properly setup, you may then proceed to enable TV out through the NVIDIA display properties control panel. The panel will differ slightly in appearance depending on whether you have an NVIDIA based graphics card that supports a single display or an NVIDIA based graphics card that can support dual displays.
1) Right-click on the Desktop and select Properties
2) Left-click on the tab labeled Settings. Then left-click on the Advanced button.
3) This will bring up the Advanced Properties. Left-click on the tab corresponding to the graphics card that is installed in your PC. For example, if you have a GeforceFX 5800 Ultra graphics card, you will click on the tab labeled "GeforceFX 5800 Ultra". A window will pop up to the left of this panel. From this left side window, select nView Display Mode.
4) You should then see a panel similar to the one above. If you are using a single display video card, left-click the "Current Display" drop down menu and choose "TV". Then click on the "Apply button to confirm the change.
5) If you are using a dual display video card, left-click over the "nView Modes" drop down menu and then select "Clone Mode". Then left-click over the "Display Pair" drop down menu and choose your monitor configuration (i.e. if you are using an analog CRT monitor plus TV, select "Analog Display + TV"). Then select the "Apply button.
6) You should now see the display on your TV. A confirmation window will pop up prompting you to confirm the changes made. Select Yes to keep these settings. Otherwise, the display will revert back to your previous settings.
If you need more assistance let me know, I'm here to help
Posted on Apr 06, 2008
  • Ekse Apr 06, 2008
    dont forget to rate the solution as fixya! thank you
    Genius:
  • 3,422 Answers
HI,
Click HERE to download the manual.It will help you solve your problem.this site has a whole list of manuals you can download.
Goodluck..
Please don't forget to accept the solution as fixya if your problem is solved.
  • 19,396 Answers
You need to activate s video from your display properties box
How do I reinstall media center on win 7 pro.
1.Type appwiz.cpl in Start menu search box and then hit enter to open Programs and Features window
2.In the left pane, click Turn Windows features on or off link.
3.Once the Windows Features window is opened, expand Media Features and then uncheck the box next to Windows Media Center.
4.Click Ok. You will see "Turning off Windows Media Center might affect other Windows features and program installed on your computer, including default settings. Do you want to continue?" message. ClickYes and then click Ok to start uninstalling Windows Media Center.
5.You will be asked to Reboot your computer. Restart to uninstall Media Center from your PC. If you want to install it again, open Windows Features window by repeating the steps given above.
6.Expand Media Features, and then check Windows Media Center option.
7.Click Ok to Start installing the feature. Done!
Feb 16, 2015 | Computers & Internet
Hp pavillion m9405f
You need a Windows DVD -- Same version as you have -- Vista / Win 7, 32-bit / 64-bit.
A local PC repair should be able to burn you a copy for a small fee.
http://fixitwizkid.com/threads/how-to-fix-bootmgr-is-missing-in-windows-vista-7.6234/
Bypass "step 1" and follow the instructions for "step 2".
Tallon41
Sep 17, 2012 | HP Pavilion Elite M9150F Desktop PC
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Apr 30, 2012 | Computers & Internet
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
Dec 04, 2010 | Microsoft Xbox 360 Console
Just got windows 7 on my laptop and had to reinstall the printer software for my hp photosmart C5180 my disk were not compatible so I installed the software for the hp website .it will print and scan but i...
Follow these steps for the Windows 7 operating system.
NOTE: HP introduced HP Solution Center to replace HP Director in 2005. HP Director is not compatible with Windows 7. If you were using HP Director with your printer and then upgraded to Windows 7, the information in this section can help you. hpweb_1-2_plus.gifhpweb_1-2_minus.gifDo I have HP Solution Center on my computer? HP Solution Center is part of a full-feature installation of the printer software. It does not install with a Basic driver installation. Also, you might have excluded the program if you performed a custom installation. Check whether HP Solution Center displays in the list of installed programs: On the Windows taskbar, click the Windows icon (c01319360.gif ), click All Programs , and then click the HP folder. hpweb_1-2_plus.gifhpweb_1-2_minus.gif HP Solution Center icon is blue (c01810967.gif ). If the HP Solution Center icon is blue, you have an older version of HP Solution Center. Go to the following "How do I get HP Solution Center?" section in this document to download the latest version.
To scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon (c01319360.gif ), click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
  3. Make any desired setting changes, and then click Scan .
Get the full printer driver:
HP offers the most current software available for your printer as a free download. HP Solution Center is part of the Full Feature Software and Drivers download. Follow these steps to check whether this option is available for your printer, download it, and then reinstall the software and drivers.
  1. Disconnect the USB cable from both the product and the computer (if you already connected it).
  2. Turn the product on.
  3. Open a new window to browse to the Get Software and Drivers page: Right-click this link, Get Software and Drivers , and then click Open in New Window .
  4. If prompted, type your product number, and then click Next . You might also need to click your model in a list of similar products.
  5. Select your operating system, and then click Next .
  6. Click the Plus sign (c02200813.gif ) next to Driver , and then click the driver that you want to download. If you need help deciding, see the information in the previous table.
  7. Click More Info , and then read through the minimum system requirements and additional instructions. You can also click View directions (c01647276.gif ) for complete download instructions.
  8. Click Download . This option allows you to install the software at any time after the download completes.
  9. Click Save , and then browse to the location on your computer where you want to save the file.
  10. Click Save . The software downloads to your computer. Hint: Make a note of the place that you saved the file, in case you want to install it at a later time.
  11. Browse to where you saved the file, and then double-click the file to start the installation.
  12. Follow the on-screen instructions to complete the installation.
Nov 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
My hp elite m9150f wont load windows when connected to a 55 toshiba led tv but it will load correctly on a smaller monitor why
It may be a cable issue,try connect a cable that is supported by your led tv to your hp elite m9150f ,if you have graphic card that attache it to your graphic card slot.
Apr 26, 2010 | HP Pavilion Elite M9150F Desktop PC
Camcoder ,PS3 or DVD player output to Laptop screen
I've had the same problem with two other unrelated HP input products in this area myself so I understand the pain. Media Center is not really well geared for nor is very friendly in the end user component input area. I'm assuming you've already tried playing a video file from your camcorder while setting up the Media Center input settings? Try a different software that will recognize your input card. Ideally, you should use any input software that came with the card itself from the manufacturer. Contact the manufacturer for a link to the original software bundle if you can't find it from their website or you may need to research your own replacement software solution for this product.
For more reading on this subject, check out this link: http://forums.techarena.in/mediacenter/767259.htm
Nov 13, 2009 | HP Pavilion dv9000z Notebook
Set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Dec 26, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hp officejet j5780 all in one
Does it give a message as No Scan Option...?
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
And if you do not have the software insatlled completly and sucessfully then you need to install the All-In-One Printer driver and software first
For WinXP:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-48994-3&lc=en&dlc=en&cc=us&lang=en&os=228&product=3301296
And click on Download only and follow the onscreen instructions
For WinVista:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-48994-3&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3301296
Good Luck
Oct 04, 2008 | HP Officejet J5780 All-In-One InkJet...
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
