Hannspree Monitor- sound is gone
I just purchased a new computer and Hannspree Monitor. I don't have any sound- I touched the volume button on the monitor and the settings changed to zero, now I have no sound at all and cannot figure out how to fix the sound issue
This is an aftermarket screen
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    what type of speaker it is ?
Got it fixed. I just wasn't pushing the correct buttons. The HP tech though made me restore my brand new computer? I new it was something stupid and simple.
Thanks
Posted on Apr 19, 2008
  • 180 Answers
Try changing the cable. or may be speaker setting is muted.
Posted on Apr 18, 2008
How do I reset to Factory Settings?
Hello Julie,
Do you own a Hannspree touch screen monitor or normal computer monitor? Either way, click below and you will find directions on how to accomplish this.
Good luck! http://www.hannspree.eu/en/faq-tvs-monitors
http://www.hannspree.eu/en/faq-touch-monitor
Mar 24, 2015 | Hannspree HANNS Computers & Internet
I just bought a hannspree monitor yesterday... and I can not get a picture on the monitor... Is there a power button on the monitor that I am not seeing... Also where do I go to get it...
Some monitors don't have real"buttons" but rather just touch sensitive spots on the perimeter of the monitor that are so dimly marked ((gray on black) that they are hard to see. So look closely at the perimeter, most likely on the right side or bottom for some kind of markings like arrows and dots or boxes. If you find them, one should power it on by just touching or pressing the marking. It wont click or depress - it just needs to be touched like you would touch a "touchscreen".
Good Luck
Dec 08, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
The white background has gone yelloe, I
Maybe you could try to restore it to its factory settings.
Apr 17, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Can't get sound on monitor
First make sure that your speaker wire is plugged in to the correct port on your computer.
The speakerwire should be plugged into the green port.
Then make sure that the volume is turned up on your monitor.
Then on your computer.
If this is isolated to only your new monitor and the above solutions do not work there is likely a problem with your new monitor's speakers.
Cheers!
Feedback is appreciated!
Dec 30, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Hannspree volume problem
hello:
also the setup from monitor the kan be set for loudnes
or check audio cable maiby failure
Aug 22, 2009 | Hannspree Computers & Internet
No Sound
Have you tried checking if the volume control is locked?
To unlock it, you have to press the < > and the menu button simultaneously to unlock it.
Aug 04, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Volume Box wont go away
Try running the game in windowed mode. Open up the WoW game, go to Video, then check "Run in windowed mode" this will let it run like any other program. (You will still be able to see your task bar however it should remove the volume box)
May 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have a hannspree 19" flat panel monitor
if there is no physical button located on the monitor itself, use your cpu's sound adjuster. it should be located on the task bar on the bottom right hand side. You can also access it in the control panel window under sounds and audio devices.
Jan 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
No sounds from monitor at all
Is the sound cable connected from the pc to the monitor. Sounds obvious but often overlooked.
Mar 07, 2008 | Hannspree HW191D LCD Monitor
Computers & Internet Logo
928 people viewed this question
David Payne
David Payne
