DENON DRA 265R RECEIVER
My receiver keeps cutting out,i still have digital display but no sound.if i switch the power off an on again it seems to reset itself.
Iv had the unit looked at ,an was told the problem was my speakers wich i have replaced. an yet the problem persists.
can u help
SOURCE:
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
  • 7 Answers
SOURCE: MY DENON DRA-435 A RECEIVER
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Posted on Jul 23, 2008
SOURCE: Denon DRA-37 Receiver-Remote lock on. Need to unlock.
Refer to the "Initialization of the Microprocessor" section of the manual (page 16 of the PDF version of the manual).
1) Turn the unit OFF using the On/Off switch (not the standby switch).
2) Depress both the Speaker A and B switches, and turn the Power ON.
3) The entire display should flash at 1-second intervals. The microprocessor should be reset, and the remote should be unlocked.
Posted on Feb 24, 2010
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
SOURCE: My very old Denon AV Receiver (DRA-55V) works fine
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
Posted on Aug 16, 2010
The scren says panel lock on. how do i get out of this mode
Denon panel lock was not supposed to be supported on this model, somehow yours is. We need to reset the microprossessor.
as denon manual states:
switch off the unit by pressing power.
keep both speaker a and b pressed and turn on the unit by pressing power.
check that the entire display is flashin at 1 sec intervals and release buttons.
the mircoprossor has been reset.
if step 3 does not work start over again.
the receiver will go back to factory defaults.
let us know if further troubleshooting is needed.
Cheers!
Feb 15, 2010 | Denon DRA-397
Receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
Feb 01, 2009 | Denon DRA-395 Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Jun 06, 2008 | Denon DRA-455 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Sep 01, 2007 | Denon DRA-37
503 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
