Question about MSI FX5200-T128 (128 MB) Graphic Card
Opengl when i play call of duty it gives error message unable to load opengl update ur driver
  • ahteshamkhan Sep 15, 2008
    how i update FX5200 drivers
U should update ur graphic card driver or ur computer is too old to run that game.
Posted on Apr 06, 2008
Wierd Colors after Playing Games ?
Dear you need to check 2 things.
1. Replace the Ram (replace the ram and then check if it gives error or not)
2. Update your Windows / graphic drivers to the latest one.. you also need to update Direct x .
Goodluck
Regards-Bilal
May 29, 2014 | Acer Aspire 3000 Notebook
Why "OpenGL/Direct3D" Problem ?
This isn't a solution as of yet but if you have updated everything and it runs fine for 14/17 minutes it could be that the card is overheating. I have run into this several times with gamers. The load on the card causes it to heat up more when playing games. Check and make sure all vents and the fan are clean for one. Over time they will clog and not cool your CPU and Video Card.
In other cases the video card is just not up to it. It will play for a time, overheat and then distort or stop working at all. Is that card adequate for the games you play?
One gaming laptop I worked on overheated and soon the graphics card would not work at all. Had to replace the motherboard.
First make sure it's not overheating, Second,check compatibility of your hardware to your game. Third, double check your drivers, completely uninstall then reinstall.
Hope this helps.
Good Luck
Minecraft failed to find accelerated OpenGL mode
You can't do anything, it's Minecraft new version which is no longer supporting your PC OR you need to install the latest Java or update the drivers.
Mar 01, 2013 | IBM ThinkPad R50e Notebook
When I try to open Call of duty it apperas the error 998 and the message buffer overrun detected
Any time I've seen this error appear when playing a game it is caused by a bad graphics driver. I would suggest going to the website of the retailer that your graphics devices comes from and updating to the most recent driver and giving it a shot.
Many different things can cause buffer overruns. This is a common attack that hackers use to exploit bad C code. In this case, since it's a video game...I'm going to say graphics driver.
You can actually see an example of the same behavior here:
http://www.techsupportforum.com/forums/f59/solved-buffer-overrun-detected-error-on-call-of-duty-1-a-459612.html
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Computers & Internet
I just get an OpenGL error when i want to run Call Of Duty(game)
ATI at one time didn't really support gl graphics that much and didn't supply any drivers for it. What you need to do is do a quick search for opengl drivers for your card. Once those are installed you should be fine.
You can try the catalyst driver from amd/ati and that should include the opengl support.
http://support.amd.com/US/Pages/AMDSupportHub.aspx
If that doesn't get it working then you will have to google up a opensource opengl driver
http://www.opengl.org/
Aug 06, 2010 | ATI RADEON 9200 Graphic Card
Problems with Palit R700
The R700 is also a HD4850 but is the X2 model. Have you checked for any firmware updates or driver updates on Palit's site here: http://www.palit.biz/main/download.php?pc_cate=vga&id=1038
I'd also check the games for their specific requirements most notably if they require Direct X or openGL drivers.
Post back with what's happening in the games and what error messages are so we can help with isolating the actual problem.
Nov 12, 2009 | Palit Microsystems RADEON HD4850, PCI...
My magellan 4040 when after trying ton update firmware keeps giving me a unable to lad application with a venus version is error
magellan 4040 when after trying to update firmware keeps giving me a unable to load application with a venus version is error! message
Dec 21, 2008 | GPS
Graphic problems
first problem
ur monitor start blink bcoz the graphic cards does not support ur game i.e call of duty world
Do this steps
first remove ur card clean with soft cloth & insert in ti slot than afterwards reinstall the game than also the monitor blinks than the same case as above i have mentioned
second problem
reinstall the crack of chronicle
or update the registration of the game
if problem occurs than the game has not been installed properly
Dec 04, 2008 | XFX GeForce 6200 Graphic Card
Unable to play the PC game Crysis
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link.
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
Mike
Apr 13, 2008 | Computers & Internet
S3 Graphics Inc. Savage4 driver,out-dated
you need to upgrade your graphics adapter meaning you have to replace with a higher memory, call of duty needs a higher memory. i have a video card with this kind and appeares the same problem like yours when i installed this call of duty1 and call of duty2 i purchased new video card 256mb nvidia and now i don't have problem encountered
Dec 01, 2007 | S3 Trio64+ Graphic Card
MSI FX5200-T128 (128 MB) Graphic Card Logo
181 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
