My computer turned off during a formatting of my mp3 player and now my computer does not recognize the mp3 player when I hook it up to my USB port. How can I format my mp3 player so i can use it again? Please advise for Microsoft Zen Micro and Philips hd6330 players.
  • 3 Answers
If u know how to format your pc i can help.
or call enginer to format and put windows xp
it depends on pc to pc.
u can get the windows xp disc and i can tell you'll how to format PC's
enjoy:-)
if u don't want change the version of u can try to view software updates on device manager on right clickin your my computers the go to hardware, to device manager. then i think u will be able to get suported software and the pc may be able to transfer data with ur gadget.
so ... if u need help ask me........
Posted on Apr 06, 2008
Computer doesn't recognize my icoustic mp3 player
replace the usb connector then tried to hooked up to the other usb port.
Jul 10, 2012 | Audio Players & Recorders
The Mp3 player is not formatted
the Mp3 player will be recognized when it is hooked up to the USP port but when you try to explore the memory on the player the disk is not fomatted.
Jan 14, 2010 | Nextar MA933A MP3 Player
When I hook up my Sansa mp3 player to either delete or load music my computer says it doesn'r recognize the usb port
Hello
I am not saying that this is the correct solution, but is works for me each time. Just plug the mp3 player into one of the usb ports on at the back of your computer case.
One other thing you can try is:
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this can help you in fixing that pesky “USB device not recognized” Windows error!
Kind regards
Andrea
Nov 13, 2009 | SanDisk Sansa m250 MP3 Player
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
I bought an mp3 player from walmart in febuary and it had a few glitches is there anyway i can have someone find out whats wrong with it becuase it wont download music
Mp3 repair services generally cost more than the player itself -minimum $229.00
Is the computer recognizing that you have an mp3 player plugged in? If not, either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If the pc does recognize the player, and it is not syncing, then the songs you are trying to load are in the wrong format, or your music service subscription has expired/doesn't have high enough rights.
Jul 05, 2008 | Audio Players & Recorders
MP3 FROZEN
Make sure the songs are in the correct format first - no iTunes allowed. it's best to use songs in mp3 format - they don't have the million problems that WMA files have.
If the pc is not recognizing GoGear: Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Jul 05, 2008 | Philips SA5125/37 MP3 Player
Deleting songs on player e250R
Step One
Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer.
Step Two
Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory.
Step Three
Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player.
Step Four
Click on single items or click and lasso multiple files.
Step Five
Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK.
Step Six
Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs.
I hope that helps!!
Jan 23, 2008 | SanDisk Sansa c140 MP3 Player
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Doesnt start up
Hi. My Inovix mp3/4 player suffered a similar fate when it crashed during a Firmware reload. The player went completely dead and wasn't even recognised by the computer when plugged into the USB port. I basically kept on trying - a couple of times whenever I used the computer - using different ports. 2 days later - 'ding-dong' - Windows XP suddenly recognised something was in the port, and I tentatively attempted a Firmware reload. Success! (Don't ask me to explain it tho'...)
Aug 28, 2007 | Samsung YP-U2X Digital Media Player
60 people viewed this question
 Grubhead
Grubhead
