Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
The Tecniks dishwasher seems
The Tecniks dishwasher seems to run forever and does eventually stop.
Water is being pumped out, but there is a smell as though the dishes are not washed properly.
I have cleaned it out but still seems the same
    Genius:
  • 1,036 Answers
Hi.
Try running a cleaning product to clear the rear pipes of any grease deposits.
If this does not work, check rear pipesare not kinked.
Hope this helps.
Posted on Jun 17, 2008
Bush dishwasher smells
Describe the smell
Jun 09, 2013 | Dishwashers
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Problem with ASKO 1385 dishwasher. Unit has manual cycle knob, not electronic. Clock/timer seems to work normally but no water is pumped in and a motor runs continually throughout cycle, even during...
CHECK THAT THE WATER IS ON TO THE UNIT, AND IF VOLTAGE IS AT WATER INLET VALVE. IF VOLTAGE THEN WATER SHOULD BE COMING IN EITHER BAD INLET VALVE OF CLOGGED SCREEN IF THERE IS VOLTAGE TO VALVE. NO VOLTAGE THEN CONNECTIONS OR TIMER WOULD BE NEXT.
Mar 09, 2010 | Asko 1385 Dishwasher
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Bosch Dishwasher Classix
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Mar 21, 2008 | Dishwashers
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Drain pump won't stop
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
Nov 22, 2007 | Bosch 24 in. SHX36L05UC Stainless Steel...
Pump Runs On After Water Is All Drained Out?
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Aug 12, 2006 | Bosch SHU9915UC Dishwasher
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
298 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
