Question about Samsung Televison & Video
Samsung le26r41bdx xeu Am struggling to tune the DTV in and get a decent number of chanels. The signal error level is fluctuating, as is the signal strength to the extent that the numbers of chanels available is yo, yo ing from zero to 40. I've had this tv for a couple of years, chucked the instructions years ago and am now setting up tv in a new room having not used it for a month. Any suggestions ?
SOURCE: RCA Scenium HDLP 50
Sounds as though your tuner module is not working or you have a lack of signal to the tuner. You need to be sure that the set hasn't been switched to a different mode ( ie: from tuner to video..etc ). If all is correct in that matter, are you using a satellite dish. If you are infact using a satellite dish, then the signal strength from the satellite is not suffecient. ( you may need to realign the dish ). If you are on a cable signal ( cable TV ) you may have a bad input cable and need to call the cable company to check their input line. If all is well with the signals coming in, then infact, you may a bad tuner module in the TV. Good Luck
Ed NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • 2427 Answers
SOURCE: No picture/sound
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
CONTACT RCA FOR REPLACEMENT PARTS OR INFORMATION
here are some contact information for rca
http://www.rca.com/content/viewdetail/1,2811,EI45168,00.html
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
1-866-SCENIUM.
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: need to auto tune channels
Try useing your remote to access the menu. Find and press "channel program". The TV should sequence each channel into the memory which will take a few minutes depending on how many are available from your cable/sattelite service. If you are not useing cab/sat, signals from just antenna will be very few and weaker
Posted on Apr 24, 2008
SOURCE: the settings on my samsung
i have read about this problem when searching for tv reviews. The problem i believe is the tv is in shop mode. This is whats used for tvs being shown in store which can be played with so the settings reset every day. You need to go into the settings and change from shop to home. Not sure where you change this but it comes up on initial setup. Hope this helps.
Posted on Jun 17, 2008
How do I go back to Digital add on search when my boyfriend scanned for the analog channels. Sanyo TV model # dp42545
Usually you have to go to chanel setup and scroll down to DTV setup up or DTV auto tuning and click on the remotes enter button and choose to scan for the Digital channels (DTV) Then tell your boyfriend that they don't broadcast in analogue anymore.
May 09, 2015 | Sanyo Televison & Video
No signal on set top box im using rabbit ears and
The problem is that rabbit ears aren't that sensitive. They don't pick up enough signal quality before the amplifier stage to get decent reception. They only work well if you're in a location where the signal strength is very high.
There are some general tips for using these indoor antenna/aerials such as getting close to a window. But if you live in a building constructed from the mid 80's onwards then there's a good chance it has foil-lined in-wall insulation which is great at blocking external TV and radio signals.
If you can get an external aerial put up then do that. Alternatively, can you tap in to someone elses external aerial feed? (With their permission, of course).
Sep 08, 2014 | Televison & Video
I've got a Baird HA32R1,$ DTV doesn't seem to work!
TRY TO SET TELEVISON TO FACTORY SETTING......TO DO THIS GO TO MENU ON UR REMOTE CONTROL AND SELECT SET UP
WHEN THERE FOLLOW THE PROMPT AND SELECT FACTORY SETTING......ALL UR PRE TUNED CHANNELS WILL GO ........AND U HAVE TO REINSTALL THEM WITH AUTO TUNING ALL UR CHANELS WILL COME BACK...........
Nov 19, 2009 | Televison & Video
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
NEED SIGNAL PANEL FOR SAMSUNG LCD TV MODEL LE32R87BDX/XEU
www.partsstore.com is a certified distributor for samsung just enter the make and model number of your set and it will bring up all the parts they carry. They usually have circuit boards for samsung
Mar 12, 2008 | Televison & Video
Hi.
3)
Chris.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
175 people viewed this question
Jerry Greenberg
Jerry Greenberg
