Question about Motorola Mobility A1200
Discharges very fast
My ming was working fine, but since last few days it is showing bunch of problems.
It discharges as soon as i run some application or call despite being fully charged. Moreover it has stopped recognising memory card too.
Plz help..is it some problem with motherboard or battery problem ?
  • pardsh Apr 08, 2008
    same problem wid my phone too :(
    It also makes a "ting" noise every now and then... I tried to find the source for the same but to no avail... ny inputs wud be greatly appreciated.
  • pardsh May 11, 2010
    WRT memory card when my phone is out of battery and I put in on charger at that time the phone is not on but if you press any key it shows you the memory card there but when I start it again after getting the battery charged the card is not shown to be there.
    I have formatted the card and rebooted the phone n times but it picks the card sometimes and mostly it doesn't.
  • 70 Answers
It may be ur battery problem may b u replace ur battery or minimal use of display settings.,n regarding the reconizing of memory card..it may work wit some reboot method..stil check out ur battery first.....try it..if it works do rate me
Posted on Apr 11, 2008
SOURCE:
When I turn my cell phone off. It says goodbye. 3 days later I go to use my Camera and my phone is dead. Does the battery need to be charged on a daily basis?? What am i doing wrong? TY
Although you have turned your phone off, it is still using a small amount of power to run the internal clock & the alarm which works even if your phone is off, when u turn it off for a short time you wouldn't notice a drop in battery power, but you turned it off for 3 days, as the battery would only normally last a day or so it has drained naturally over 3 days it may also be that the battery is showing signs of dying as well, make sure it is at full power when you turn it off & plug it into your charger for a hour or so every day, you can get a new battery for it from ebay, they are not expensive, & try that, compare the times they both last.
Feb 23, 2015 | Nokia Lumia 520 Windows Phone Black
2001 Bonneville! Several weeks ago, had trouble turning the key in the ignition - sometimes would turn, sometimes wouldn't. Then the Service Engine Soon light came on and the car stalled out a few times...
Service Engine Soon came back on and the car is again stalling ????? Did you have it checked for DTC'S - diagnostic trouble code's ? Service engine soon light on , codes will be present !
Apr 20, 2017 | 2001 Pontiac Bonneville
Printer will not print from any application, notepad, or wordpad or XP troubleshooter, nor will it run self-tests. When turned on, the lights flash -- self-test appears in display area, but nothing else...
TRY THIS PROCEDURE
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Sharp Office Equipment & Supplies
I had installed the WiFI router successfully and it worked for few days. However, since last few days, as soon as the laptop starts, I get an error saying the 'Device has stopped working'. The error...
Well if your able to get on the internet and the belkin is installed correctly, you can simply turn off the belkin.exe app from start up and it shouldn't hurt anything. To turn off the app click Start, then RUN and type: MSCONFIG <Hit the Enter Key>
Click on the Start up Tab and find the belkin.exe app and un-check the box. While there you can also un-check other programs you don't need to start up with the pc to speed it up. Click OK and close and reboot the pc. Once your back at the desktop, a window will appear. Click the check box at the bottom left and then click Close. (you won't see it again)
Hope this helps! :)
Oct 28, 2010 | Belkin (F5U273)
Hymer/mercedes S700 starline 2004 - batteries being discharged
If you suspect the computer is draining the battery, unplug it. Test to see if the ½ amp draw disappears. If it does, there's your problem. CHECK all of the ground connections in that area and beyond, just one poor connection may be damaging the electronics.
A draw like that is only a few watts, it could be as simple as a compartment light, like a glove box type of space. On cars, an underhood or trunk light is commonly the fault. Check things like that first!
Nov 20, 2017 | Electronics - Others
Mouse and keyboard lock in and out of function.
its may be conflicting between your router and your os
Jul 05, 2009 | Computers & Internet
Screen works in playback mode but turns off in camera mode as if batteries are going dead.
For some reason, Fuji does not emphasize that if your batteries get low, this is what happens. You just need recharged batteries or new batteries. Be careful with rechargables--before recharging them when this happens, you first have to drain them using the discharge mode of your camera. Then they will take a complete charge. (Good for some 300 charges or so, I believe.) But if you don't discharge them first, they will take less and less of a charge, and last shorter and shorter. If you use regular batteries, they might not last for 50 pics before running out of juice.
Oct 27, 2007 | Fuji FinePix E550 Digital Camera
Low speed burning problem on SH-S162L TS08
http://www.winhlp.com/tools/resetdma.vbs
save and run this script on your computer!
Oct 14, 2007 | Samsung (SH-S162L/BEBN) DVD RW Burner
MOtorola Ming keeps shutting on and off
check the batery of h/s, or contact motorola care center
Oct 14, 2007 | Motorola Mobility MING A1200
Motorola Mobility A1200 Logo
71 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
