FixYa.com
Tags:
Rainbow E series Canister Wet/Dry Vacuum
No power in power nozzle
posted by pjs5451 on Apr 06, 2008
vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 12, 2008
Not Rated (0)
Agent Don
Rank:Wiz Wiz
Rating: 82%, 97 votes
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
where is the repair center
where is the repair center for... Answer This...
Vacuums
how to install front wheels
how to install front wheels on... Answer This...
Rainbow Shampooer
Where do the two tubes go at... Answer This...
Rainbow E Series
Hello...I read your answer to... Answer This...
Rainbow Rainmate
I have a Rainbow Rainmate with... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
