Question about Creda C361E Electric Kitchen Range
Creda EDCW60 How does one remove the glass panel behind the control knobs
3 Suggested Answers
SOURCE: remove panel behind ignitor knobs
I found the solution at Fixitnow.com. Apparently the knobs are VERY difficult to remove and must be pried off using two screw drivers on either side of the knob and working back and forth. I sprayed them with WD40 before replacing them.
After getting past this poor design issue, the remainder of the repair was very simple, as I expected it would be.
Posted on Oct 10, 2008
kachbibi1
  • 979 Answers
SOURCE: Do I need to remove my Creda Europa 48132 built in double oven unit from its housing to replace thermostat in main oven compartment, or can it be done from removal of control panel?
You may have to do the former. You will have your temp probe to deal with as well.
Posted on Feb 25, 2013
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
The glass panel behind the control knobs has shattered can I replace this model is stoves 720ef
The best bet is STOVES for a replacement - if they have one. It is relatively straightforward to replace. With all the buttons and knobs removed, there should be two screws underneath the panel , i.e. pointing upwards at either end of the panel,. The panel will also have two lugs along the top edge that locate into the top off the oven. The panels lugs should be first located into the oven before the screws are inserted. It may be a bit of a struggle but can be done.
Sep 11, 2011 | Stoves 720EF Electric Double Oven
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Replace lighting behind the heater controls
Yeah , something would have broke for real had you pried it any more.
There is a bulb just below the control panel that lights the panel up... and more screws to remove to access it. The ones behind the knobs need to be replaced ( they hold the switches to the face plate), and you need to unscrew the ones behind the trim and above the ash tray.
The trim comes off in one piece (held by clips).
Nov 22, 2008 | 1998 Toyota Camry
Remove panel behind ignitor knobs
Sep 08, 2008 | DCS RGS-305 Professional Gas Kitchen Range
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Aug 02, 2008 | GE WSXH208A Front Load Washer
Creda C361E Electric Kitchen Range Logo
77 people viewed this question
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Pamela Leach
Pamela Leach
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
