Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it. Mic Wiring Stock
1-Shield
(ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
mira el magnum force 257 es un radio de 10 metros y modificable a 11 metros , los canales mas usados en 11metros son el canal 9 osea 27065 mghz , o si tienes licencia puedes usarlo en 10 metros 28,000 por ahi para arriba se usa mucho 28315 en usb , en 11metros se usa am mucho, busca en yahoo , el manual de servicio para que te familiarizes con el suerte.
You might try calling the Company for parts,,1-877-624-6869 or e-mail them from their site https://www.rflimited.com/Site.asp?CID=2 Let me know how this helps you, sorry for the delay,, Mechanic
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
