Mine laptop have the same problem, even if my battery get 100% charged, it remains in the same condition that keeps flashing from green to orange. Pleas if any one can tell what is wrong with battery.
If you ran the battery to the point of almost draining it, then the light being orange is from below 25% charge
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: BATTERY LIGHT FLASHES ORANGE
hi,
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
