Hi my panasonic VIDEO PLAYER has the code F03 come up on the front when I put a video in, now the power goes off to it and it wont eject the tape in it. I would appreciate your help here please....
  • Anonymous Apr 08, 2009
    I have the same VCR and same problem, looks like sending it to the scrap heap since the labour cost alone is more than a new VCR.
Hi, the problem may be typical for this VCR , you must to change 2 mechanical parts, one is the plug on the loading motor , the other is a rod, but you must to have experience in VCR repairs, becouse of that the best solution is to find a Panasonic service center
Posted on Jun 04, 2008
Hi. I posted this question in the hope of getting some help with my VCR, as it was advertised as a free site... oh its free alright to post the question but to get any help you need to pay..... SO I SENT MY VCR TO A REPAIR SHOP LOCALLY !!! thats how I fixed the problem. with NO HELP FROM THIS SITE AT ALL........ Thanks but no thanks...........
Posted on Apr 07, 2008
How do I fix error F03 on my Panasonic NV-HD600BD vcr?
If you wish to get more details visit the site linked here. Error code list and details of many popular brand devices are given.
Feb 23, 2017 | Panasonic Televison & Video
go to and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Aug 27, 2012 | Panasonic Televison & Video
Wont do anything getting F30 error code
Do you mean F03? that error is known in Panasonic video products. It usually applies to the VCR, which means a mechanical fault; such as loading motor and/or mode switch. The switch itself would be on the main board under the VHS deck, and can be cleaned with special electronic spray cleaner, and electronic lubricant (after the cleaner), but for more reliable results, the mode switch may require replacement, which should be done by a workshop. If this is the only issue you have with your combo unit, it shouldn't cost too much to correct this problem. Either try cleaning the switch yourself (being careful when opening unit), or submit to workshop for quote and professional repair.
I have never heard of F30 as a video/DVD error code before. That error applies to some Panasonic air-conditioners and is a system error.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Vcr panasonic NV-HD 660B When it is off and switch it on,works everything properly for about an hour.Then video cassett comes out and the error message comes-F03
You have a K-Deck mechanism. If you put "Panasonic K-Deck" into Google you should find further service information.
However I can tell you that F03 means that it is locking up as it unloads. The cause of this is listed as Load motor or drive, timing, mode switch. The fact that you have operation of it for some time shows it might be the mode switch. If it does eject normally at all, before it starts playing up also would point to the mode switch. You might get away with a spray of Servisol Video 40 on the mode switch. If not take care to remove it, as it needs to be set up correctly or it will create tuns of problems. You should be able to get one from Currys Partmaster.
It might look like this:
Oct 26, 2010 | Panasonic Televison & Video
Panasonic vcr wont release tape has fault code f03
It sounds like you have a model that uses the K-Deck, you might need to confirm this, by putting the model number on Google and the words "K-Deck". However if it is a K-Deck F03 means that it locks up when unloading. This can be put down to the loading motor, or the drive system, perhaps even the mode switch, also the timing of the mechanism.
I suspect you will need the service manual, as setting up a new mode switch is tricky. The good news is that you can get the K-Deck manual online free, all you need do is do a websearch for "Panasonic K-Deck manual". It will even explain how to the tape out of the mechaism.
One tip you can try however is spraying the mode switch with Servisol Video 40, if you think it's the culprit, it could have just got some dirt in it, not saying it could be that though, but worth trying before replacing one. (Curry's Partmaster if you need to replace the mode).
Jul 04, 2010 | Panasonic Televison & Video
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Fault code F03
No drum rotation signal. A shop visit is required. Sorry..accordianman
Apr 23, 2008 | Televison & Video
Error Code F03
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Televison & Video Logo
313 people viewed this question
Top Televison & Video Experts
