When i turn the tv on the screen is green and green lines over it. Then the tv turns itself off and back on again. It is an artos MF premium Metz Television. Please help Yvonne
    Genius:
  • 3,422 Answers
HERE ARE FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO:Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
THREE:Go into the OSD and make sure the settings are correct for the mode you are using it
FOUR:The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
After the above you still have the green screen you may need a service tech. I have never seen service on a large set of this kind to be less than $200; usually more. In this case, if the reset and double checking all the function settings does not solve the problem I suspect it is a video driver problem. I would expect the service charge to be on the low side or in the $250 area.
Goodluck,
Please don't forget to accept the solution as fixya.
Posted on Apr 06, 2008
  • Priya darshan Apr 06, 2008
    Please don't forget to rate the solution
    Genius:
  • 1,447 Answers
Try to disconnect cables from the back of tv except the power cable, turn it back on. if issue persist there is a problem with the bulb, try reseating bulb/lamp. then power it back on.
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 06, 2008
    try this as well
    Get into the service menu of the TV by pressing both the + and - buttons
    under the front flap of the TV and switch the TV on at the same time (not
    from standby but cold). Keep the 2 buttons pressed until the service menu
    shows up and then press 'initialize Eprom' at the initial menu, this should
    reset anything untoward back to factory levels.
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Hitachi S57500 projection tv turns itself off
Hi, I`m afraid it`s not good news, you have a bad green picture tube, video-tek
Feb 10, 2009 | Hitachi 57S500 57" Rear Projection...
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
Picture changes focus/sharpness instantly and then recorrects
Hi
You can try and get more infornation for me.
Go into the the menu by pressing the WEGA GATE button on the remote. In the sub menu of picture adjustment switch the DRC-MF setting to off. It should read normal.
See if this stoppes your focus problem.
If it changes let me know for further directions.
Feb 24, 2008 | Sony KP-57WS500 57" Rear Projection...
TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
