Question about LG Televison & Video
LG CT-29K30EX 29" TV plugged
LG CT-29K30EX 29" TV plugged in and switched to standby mode it starts making a clicking sound. I can't get it to switch on it just sits clicking away in standby mode
LG CT-29K30EX 29" TV - We have the same symptoms as described. If you are a person who is not afraid of opening the back cover of your TV and replacing parts inside. this tip is for you. Contact a service person if your not 100% sure. Its actually easy, it involves replacing a small capacitor in the power supply section. You don't need to troubleshoot coz i've done that for you for free. Find this capacitor in the power supply. C801 with a value of 100uf / 35V. De solder and replaced it with the same value or a much higher Voltage rating e.g. 50V. Done! your T.V. is alive again. - Rey Tilles - New Zealand
Posted on Aug 06, 2008
SOURCE:
Akai TV CT 2579A will not turn on. It is in standby mode, and pressing "on" with the remote causes a click noise but unit stays in standby mode ... the manual on/off switch does the same thing...
Suspect the problem is in the control circuit of the TV. Often the detector will go bad and have to be replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
Hope that helps........
Aug 29, 2008 | Televison & Video
LG 29" COLOR TV HAVING MODEL NO. RF29CA40 plugged in and switched to standby mode it starts making a clicking sound. I can't get it to switch on it just sits clicking away in standby mode
my tv exactly same problem , from what ive read our tv 's are not worth the ammount it would cost to fix , around 250 dollars, im gutted! il let u know when i find out properly
Sep 19, 2013 | Televison & Video
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
Mar 26, 2009 | Panasonic CT-36SL13 32" TV
Open Questions:
Televison & Video Logo
406 people viewed this question
Ekse
