make sure the light switch is powered off then (after letting it cool if hot) turn the bulb slowly untill in your hand then take new light bulb and turn it clock wise till snug and now go flip switcha and wa la you should have light
Either the cord is bad or the reset button has tripped. It could also be a bad hose or switch. Canisters are harder to diagnose because the electricity for the power nozzle runs from the canister to the power nozzle.
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
Power source
Travel alarm clocks will need to
have some sort of power source. Depending on the type of alarm clock,
it might be battery-powered or it might have a cord that needs to be
plugged in. Battery-powered alarm clocks can take mini watch batteries,
AAA batteries or sometimes AA batteries. Travel alarm clocks, because of
their tiny size, usually have the small batteries that need to be
bought from a watch store or a dollar store. Before you leave, make sure
you have a working power source and can turn it on.
Changing the time
After you reach your final
destination, power the alarm clock on. Now you'll need to set the time
and date correctly. Check a watch, cell phone or television to get the
exact time and locate the buttons or dials on your alarm clock. On some,
there will be a "time" or an "hour" button you need to press and hold
to activate the alarm time change. While you are holding it down, turn
the dial, press the hour button or press the (+) button until you notice
a time change. On others, simply pressing the hour or minute button
will let you change the time shown.
Setting AM/PM
The AM/PM option is critical in
setting your alarm clock correctly. Make sure the LCD display on your
clock has a light beside the correct AM or PM setting, or look for the
letters AM or PM on the display. If you get this wrong, the alarm won't
go off in the morning!
Setting alarm time
To set the alarm time, look for a
button or a switch that says alarm. If there is a switch, move it to
the alarm setting. If it is a button, you'll need to hold it down until
the time starts flashing, signaling time to change the hours and minutes
to the desired alarm time, or hold it down while you press the hours
and minutes buttons to reach the alarm time you want.
Turn alarm on
Now double-check that your
regular and alarm times are correct by switching the switch back and
forth again, or by pressing the alarm/time buttons long enough to read
the time set. There should be a picture of a bell somewhere on your LCD
display showing that the alarm is set to "on." If there isn't, look for
the on/off alarm button and move it to the correct position.
Music options
The last step is finding the
alarm wake-up option. Not all travel alarm clocks have this option, but
if yours does there will be a switch or button that lets you choose to
wake up by a buzzer, the radio, a CD, or another device.
http://theguidedb.com/search/the-acurite-weather-stations-00605rx-wa-guide.html THE ABOVE LINK WILL GIVE YOU THE USER MANUAL. ITS IN PDF FORMAT AVAILABLE FOR DOWNLOAD. THIS WILL SURELY HELP YOU TO CHANGE TIME AND MUCH MORE. REGARDS. PLZ. RATE THIS
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
