Question about Samsung CLP 300 Laser Printer
Beeping from Power Module
I have a Samsung CLP300. I unfortunately bought the thing off ebay, as new, or some I'm told. Its was printing fine to start with but after I left it on over night when I came back to it I could hear a intermittent beeping / chirping.
Tried reinstalling drivers etc however at this stage I new it was a hardware problem anyway.
I noticed that whn I opened the case however it the LED panel turned on, the computer recognised it and the beeping stopped. But closing the cover dropped the power once more and the beeping stopped, with the computer once again not recognising it.
So I approached Samsung in the US and in the UK (am based in the UK) but without solution. Normally faults are reported on the LED panel covering things like jams, toner, cover open etc.
So in vain I started to disassemble, with the aid of a service manual. I found where the sound was coming from, it was the Power Module positioned front left of the main board making the sound, from what looks like some sort of capacitor?
I have found someone that can supply a new power module and it seems easy enough to replace but wanted to check if anyone else had come across the problem first before I put money into a problem which may not yield a solution. After all I only paid so much for it.
Be really grateful of some guidance.
Many Thanks
Mike
  • mikesumbler Apr 06, 2008
    sorry couple of typo's in here: -
    - beeping 'started' after closing case
    Problem Solver:
  • 5 Answers
Where did you get a service manual copy?
Posted on Sep 20, 2008
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
How to reset printer counter samsung CLP300
There are two major counters in this samsung CLP300 color laser printer.
I will give you the answers for both.
The standard one is the page printed counter.
You can not change that
The only way is to change the system board or get an used printer
(AS LOW AS $80 now!) and swap it.
The other set of counters are the toner counters.
eBay seller tpstock6898s.gifhas them
Set of Samsung CLP 300/CLX 3160FN reset Chips
eBay Item number: 260468470362
http://cgi.ebay.com/Set-of-Samsung-CLP-300-CLX-3160FN-reset-Chips_W0QQitemZ260468470362QQcmdZViewItemQQptZBI_Toner?hash=item3ca521725a&_trksid=p3286.c0.m14#ht_790wt_1165
You can pick up the whole 4 chips set to reset the data to the printer for under $10.
Please post more information on what you like to reset.
I will follow up on this post.
Aug 29, 2009 | Samsung CLP-300N Laser Printer
Samsung clp300 color laser printer not printing
The cartridge dried out and the moisture/liquid sensor will no longer detect new fillings though the layer. A good refill needs to be done before the ink is out. These are tedious little critters. Try the nozzle cleaning procedure several times(through your printer's software. Take out the cartridge and set the jets on a cotton ball soaked liberally with cleaning fluid. Run the nozzle cleaning procedure again.
Jul 05, 2009 | Office Equipment & Supplies
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
Invalid black toner replacement cartridges
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
May 20, 2009 | Samsung CLP 300 Laser Printer
Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for 2006, and a different one starting in 2007. I have the older 2006 printer, and the current firmware is only for the new 2007+ print engine.
I talked to Samsung support here in Korea and fixed the problem. They sent me to their special tech support website at www.1479.co.kr (only in Korean) and I was able to download an older version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download the two files at the top, then extract the archive. Drag-n-drop the correct firmware file onto "usblist2.exe" and the printer will be flashed with the firmware (must be connected via USB if you're using the CLP-300N model).
Apr 06, 2009 | Samsung CLP 300 Laser Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
Samsung CLP 300 Laser Printer Logo
224 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
