My panasonic SA-AK750 hi fi stereo keeps saying disc change error and the changer will not open or change disc. ive tried turning it off at the wall and then turning it on again but its still displaying cd changer error
Hi
The problem is mechanical, Disassembly carefully the section mechanism, clean all with isopropilic alcohol and grease again.
Posted on May 15, 2009
    Genius:
  • 1,550 Answers
Tienes que llevarlo a un centro de reparaciones ya que el sistema de cd esta fuera de tiempo por eso no funciona nada.Hasta que no lo pongan a tiempo no va a funcionar.
Posted on Apr 06, 2008
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Jul 20, 2010 | Philips Audio Players & Recorders
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
Panasonic sa-ak20 5 CD changer does not work
hi i heared about you cd changer problem. i have a same hi-fi system an i have the same problem. it seems it appears when you hit.move or turn upside down the cd changer. you can solve it by unscrewing the top of the hi-fi with a regullar screw there should be 5 screws on the back and 4 on the sideways after this take the top off by pulling it upwards then you should plug in the hi-fi at the outlet and try to change the cd if it doesn't work try seeing if any of the cd is stuck in there if it is try to push it with your fingers but watch your fingers and do not touch any metallic part if in doesnt work like this eithertray looking if the cd-reader is stuck in any way......try to free it with your fingers but watch your fingers too if it doesnt work try to contact me at :tavi0815@yahoo.com il help you with any sound-sistem problem :D ;)
Sep 07, 2008 | Audio Players & Recorders
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
907 people viewed this question
 Grubhead
Grubhead
