Question about Dell Inspiron B130 Notebook
Display goes haywire...
I have a Dell Inspiron B130 PC and all of a sudden the display screen seems to be acting up. It's like the color is washed out or these lines will appear across the screen. When adjust the screen it goes back to normal until I let go so I'm guessing something is loose. Does anyone know the best and cheapest solution?
  • B1u3 Apr 07, 2008
    I removed the hinge cover but the cable appears to be intact ... how difficult is it to replace the display?
  • Dell Master
  • 1,183 Answers
The easiest solution is remove the hinge cover and check if the LCD cable got cut.
http://tinyurl.com/oyrzt
follow the following instructions to replace display assembly
http://tinyurl.com/hbk5x
You can also run diagnostics.. power on and press F12 on dell logo slowly 5 times
Select diagnostics and follow on screen instructions.If the LCD fails its time to replace the same.
Posted on Apr 06, 2008
The screen is 2 inches from each side and i cant get it to enlarge
Hello, it seems like your display settings are incorrect. Right click on the desktop, and go to display properties. Then go to settings and adjust the screen resolution to a larger size.
Mar 06, 2011 | Dell Inspiron B130 Notebook
My screen on the laptop just goes black all of a sudden. It also would go dim or flicker occasionally, kinda like a loose plug. HELP
what i can suggest is try a known good monitor, if its ok on the external monitor - try reseating the lcd/display cable refer to instructions @ http://support.dell.com/support/edocs/systems/ins1300/en/sm/display.htm#wp1105347
if still the same, lcd needs to be replaced.
Nov 10, 2010 | Dell Inspiron B130 Notebook
PINK PROJECTOR SCREEN DELL B130
Generally, a cable connection or cable issue. not all the color signals are making it to the projector. Try reseating the cable connections on both ends. If no changes, then try another vga cable
Mar 18, 2010 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 screen screen glitch
This could be a screen cable problem but it is normally a faulty screen even though it may look like a loose connection. Get a technician to check it for you.
All the best.
Jan 19, 2010 | Dell Inspiron B130 Notebook
Narrow laptop screen on a dell inspiro 130
Start-Control panel-display, if you can't read anything,
Shut off and start up and hit F8 to go to safeMode, then make your repair under display in control panel, Start with 800-600 resolution
Jul 30, 2009 | Dell Inspiron B130 Notebook
Display goes blank after about a hour after it is on.
Hi
Run a test on the system first and also update video and bios.
Drivers can be downloaded from www.support.dell.com
Running a test can be done by pressing FN+power button and turn on the system. Fn is the key found on the left lower side of the system
otherwise press F12 when you start and the system and see a dell logo, go to diagnostics and run a diags and let me know if you get any error messages
thank you
rakesh
Dell Laptop Expert
Jan 09, 2009 | Dell Inspiron B130 Notebook
B130 Monitor Problem
Connect an external monitor at the back of your laptop and see if the display is fine. If the display is fine with the external monitor, it means to say that there's something wrong with your LCD's backlight. You may have to contact Dell Technical Support to check if your system is still under warranty.
Thanks! :)
Aug 26, 2008 | Dell Inspiron B130 Notebook
Dell lcd display
if it is just half of the screen and the rest is black- you need a new screen. If it is half the screen all squished together (you can see the whole desktop) you need to reload the video driver
Nov 22, 2007 | Dell Inspiron B130 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
202 people viewed this question
Alun Cox
