Question about MSI M510C Notebook
CANNOT turn on laptop sometimes...
I cant turn on my laptop even i have press the on button for few times, but some times i can turn on it, may i know what is the problem of my laptop??
  • 123 Answers
Hawhaw,
ur power on switch were loosen in the inside..there are sum parts that has nott connected peoperly..or simply say,the wswitch cant reach the thing inside..
Posted on Apr 06, 2008
Cmos settings for acer aspire m5641
to reset the cmos you only need to take the small round battery off the board for a few minutes. if your laptop is not keeping time then you need a new battery on the board. ( you will find you cant get on websites when your laptop has the wrong time on as its a security risk ) to enter the bios ( which i would not if i didnt know what i was doing ) turn off laptop/press power button to turn it on/keep pressing F2 while its booting up ..but be careful in there
May 24, 2015 | Acer Computers & Internet
Some of my keyboard buttons are typing numbers when i press a letter. what do i do?
This issue could be from viruses. I have come across a few viruses that switched around a few of the keys from letters to numbers. Have a technician or someone you know who's computer savvy do some virus removal on your laptop.
Also, make sure that the Fn key isn't activated. Sometimes haven't that activated will turn letters into numbers without you even knowing.
Hope this helps.
Jun 25, 2011 | Acer Aspire One D255-2670
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have an intermittent power-on issue with my Dell E4200. Sometimes it is very hard to turn on - pressing the power button makes the button light up, the fan runs for a few seconds, then the caps lock icon...
Try performing a hard reset on the laptop. Remove the battery and all peripherals connected to the laptop (including the AC adapter). Once everything is removed/disconnected, press and hold the power button for around 15 seconds. This will drain all remaining charge in the motherboards capacitors which usually causes this kind of issue.
Hope this help. Goodluck!
Mar 28, 2011 | Dell Latitude E4200 Notebook
MY toshiba satellite m35-s349 DOESNT TURN ON UNTIL I KEEP PRESSING THE POWER BUTTON AND [MAYBE AFTER FEW HOURS OF WAITING OR FEW DOZENS OF TIMES OF PRESSING THE POWER BUTTON] IT TURNS ON...WHILE OFF EVEN...
this sounds like a problem I had with my m35 a few years back. The problem is in the Maxim chip. It's a one hour repair. I wrote a tutorial and it helped hundreds sofar to repair their laptops. Check out www.ebooksandtutorials.com for immiediate download of the PDF illustrated repair tutorial for the Toshiba m35 failure to boot issue
Sep 28, 2010 | Toshiba Satellite A60 Notebook
Cant us the remote dont know how to accss the
These are the steps on how to program your Universal Remote Control to your device even without the list of code.
1. Manually turn ON your device.
2. Press and "HOLD" CODE SEARCH
3. Press and release the device button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the device turns off, press and release ENTER.
7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 14, 2010 | RCA Universal Remote Control
Everything (icons text etc) on my acer laptop computer suddenly went huge & I can not get to go back - tried rebooting & have even run a restore system to a previous day on it & nothing helps
HI there will you please follow the steps.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
If no luck after that all then you have to format your OS & installed it again.
Feb 09, 2010 | Acer Aspire 7520-5185 Laptop
My asus laptop cant turn on
you need to replace the Power button...
Apr 12, 2009 | ASUS AC Adapter- Universal Notebook AC...
My toshiba 1805-s74 will not turn on
Hi Russ,
Sometimes a laptop will appear in a ghost state, not off, or on if you sometimes shut it down, but close the lid too fast. Try pressing and holding the power button for 5-10 seconds. This should turn it off completely. Then give it a few more seconds and press the power button again to turn it back on.
Hope this helps!
David
Nov 17, 2008 | Toshiba Satellite 1805-S274 Notebook
HP pavillion ze4420us
press the reset button on the BOTTOM of the computer
Nov 19, 2007 | HP Pavilion ze4420us Notebook
MSI M510C Notebook Logo
82 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
