Question about Samsung WF203ANW Front Load Washer
Washing machine instructions
I bought this at a discount because of no instructions, please tell me where I can download them. Also, how many transit rods there are to remove
The Samsung website usually has downloadable manuals for their products - I found mine on here
http://www.samsung.com/uk/support/download/supportDownMain.do, yours should be there too
Posted on May 11, 2008
Brand new washing machine - have only used once and it moves and jumps around ALOT !!! Is there something I need to remove from the machine before I use it.
If you have not already done so, then you must remove the transit bolts located at the rear of the washer.
There is usually 2 or 4, and they are clearly visible, it should tell you in your user instructions.
Dec 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I just bought a bosch washing machine maxx 7. While spinning the whole machine moves. Did I install wrongly or must I lock something. I have to hold on to the machine tightly so that it will not move. ...
The problem might be that at the back of the machine the transit bolts are still in to find out how to remove look in manual. The way you described it sounds like the transit bolts are still in and need to be removed. if the bolts are out the machine need to be levelled and feet checked so that it is all secure. hope this helps.
Sep 18, 2010 | Bosch WFO2862 Front Load
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Brand new washing machine wandering on spin cycle
It sounds like the transit bolts or some of the packing is still in place. Running the machine with these in place can do serious damage.
Thankyou for using Fixya.
Feb 14, 2009 | Washing Machines
Transit struts need taking off a miele w3748
The struts are just turned about 90 degrees and pulled from the rear - make sure you keep these in case the machine is to be moved - they need to be reinstalled
Nov 27, 2008 | Washing Machines
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Samsung WF203ANW Front Load Washer Logo
235 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
