Question about Car Audio & Video
Hi all,i am looking for a steering wheel boss for a t5 vw transporter van,any help would be greatly appreciated, kind regards,GEE
  • 185 Answers
So cant help u wish i could
Posted on Apr 06, 2008
Vw t5 fuse box diagram
Maybe it hepls you. On this website (link below) you find Fuse box layout and description for Volkswagen Transporter T5
Volkswagen Transporter T5 ESSENTIALS from September 2009 fuse box diagram...
Sep 15, 2013 | Cars & Trucks
Why is it when my Vw Transporter T5 warms up white smoke comes out of the exuast
Whit smoke with a sweet smell means you have a leaking engine cylinder head gasket.
Jun 22, 2012 | Volkswagen T5 Cars & Trucks
2002 VW Beetle 1.8T\r\nRemoved horns and tested using battery & the both worked, reinstalled & press horn on steering wheel & nothing just hear a clicking noise from where I pushed on steering...
Generally the steering wheel boss switch does not wear out (the horn is not over used!). I would check the fuses and then the relay and if they look OK check the wiring form the relay to the horns for continuity. Use a voltmeter to check that voltage is being supplied to the relay when the horn switch is pressed. Then check that voltage is being output by the relay in response to this voltage input. If this all looks OK then there is some kind of break in the wiring to the horn unit
May 03, 2011 | 2002 Volkswagen Beetle Turbo S
Lack of power
Turbo failure is never normally intermittant so I doubt it is a turbo fault.
The wastegate relys on a signal from the ECU via the MAFS.
Mass Air Flow Sensors are very common to fail on VW TDi and this also fits in with your symptoms.
Kind regards
Lloyd
Feb 21, 2010 | 2005 Volkswagen Microbus
Vw transporter t5 1.9 light has come on for the exhaust system any ideas how to cure
Hi you may have a faulty lambda sensor, would be worth taking it out and cleaning it to see if that cures it, wont cost you anything to try.
Regards
Dan
Feb 03, 2010 | 2007 Volkswagen Golf
VW transporter power problem
Hi nick. I have a T5 04 model and recently had the same problem. i was told it was a blown turbo so i had a friend look at it and turbo was fine. got vw to run a diagnostics and it had a broken wire running from the charge pressure meter. replaced for 9 euro. 3 weeks later same problem and it turned out to be a loose plug on the air mass meter. now its perfect again. apparently what happens is that if the engin management is getting a wrong reading from the pressure meter it limits the van to 40 horse power for fear of blowing the engine. whenever i switched the van off and back on the problem would fix itself but as time went on it got worse until complete failure. the wire is located under the coolant resivoir. dont know exactly where though. email me on paulblackpb@gmail.com if you need to know more. if it does turn out to be the turbo (which i doubt) then there is a website called CRTurbos that seem to be the cheapest around. but i seen another forum where the turbos were replaced and the problem remained. I suggest first look at the charge pressure meter.
Jul 03, 2009 | 1996 Volkswagen Jetta
Vw transporter t5 04 van t30 2.5
I had the same problem with my T5 130. My mechanic replaced the head gasket to no avail,then we checked the oil filter,that was ok.then we went on to a web forum and found out that the AXD engine suffers from water pump failure.We took it off and it was corroded,the seal had failed and was pumping water into the block.My advice,CHECK WATER PUMP FIRST! Good luck Marc,Somerset.
Nov 28, 2008 | 2005 Volkswagen Microbus
Car Audio & Video Logo
123 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
