Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Machine error a1 - Manual Clean
What do you mean by Manual clean ? How get access to the ph ? I succeed to remove the black protection on the top of the PH, but impossible de move the ph ? I'm using no regular ink and I suspect that it is clogged.
But if this is the real solution, why my printer mention this error message "machine error A1" which seems to be more linked to the cover instead of the ph ?
Tanks for your answers
Regards
  • 832 Answers
First things first for brother ph:
Those cant be cleaned from outside! The cleaning procedure is alwasy from the inside by help of the original ink
(which contains additives of special cleaning fluids). This is due to the very special technique of electro-piezo ph instead of bubblejets (canon system) which can be cleaned sometimes from outside.
Another fact is that due to the tube (capillaries) system its quite often possible that air bubbles have grown when transported from refilled carts to ph. This air bubbles prevent the nozzels to work well or itz seems to the user that the channel is clogged.
Some advice to generic ink:
do refill original carts only. This is because of several reasons (prevent staining, malfunction and more trouble).
Buy refill DYE-ink (universal ink from jettec or inktec work excellent) and some glycerol (85%- glycerin alc.) at the drugstore. Mix 2ml glycerol with 10ml of C/Y/M ink very well and refill the C/Y/M carts with that: drill a hole of 2mm into the top of the cart (e.g. O of brother brand name).
For bk mix 1.5ml glycerol with 15ml bk dye ink and shake very, very well before refilling the cart.
So here is what you can do to get rid of the clogging:
Plz use 4 new, full ORIGINAL brother carts (quite costly, I know)..
Place them in and make sure they are secured.
Press menu then start bk then fourtimes arrow up. machine will be in maintenance mode.
press 7-6-4 then start bk copy.
machine will initialize the carts, by refreshing ink in tubes and ph, delete air bubbles and do some power cleaning.
when finished press 7-6-3 then start bk copy.
Machine will do an extra power purge.
when finished leave maintenance by pressing 9 then 9.
Do a test print after machine comes up again.
If your lucky your generic ink hasnt destroyed the ph!
Otherwise you need a new mfc due to the fact, that a ph is very costly!
BTW: Be very carefully when clicking the ph cover back into position! Wachtch the upper leftside: dont break the small platic guide which leads the ph on the rail.
And...
to delete error A1 (scanner top open) simply make sure, that the top is in right position ;-) (If you have read out the error code from maintenance as an error: this is NO error! Its in info which have all brother printers when the scanner is opened the first time ;-)
Posted on Apr 07, 2008
I have an error code 0310 on konica minolta magicolor 1690mf how do I get it off and get machine working again
The error code 0310 means the SOS signal is not detected within a given period of time after the output of the laser has been started.
To fix this clean the PH (laser) Unit by removing all the toner that gets inside. If that fails, you need to Replace the PH unit (p/n A034 R707 00). If the error returns again, replace the PRCB (p/n A034 H009 07).
Oct 11, 2014 | Konica Minolta bizhub Office Equipment &...
What does F 02 code mean ?
Normally a simple fix: Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out. With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out clean and install it back into washer. Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
May 04, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
How do you fix density shutter error and sensor calibration error on OKI C9650 Printer
The shutter protects the density sensors and keeps the windows on the sensors clean, until they wear out. Replace the shutter assy (part number 42755401) and clean the sensor windows.
If this doesn't solve the problem, you may be at the beginning stages of a broken gear for the top cover mechanism that protects the LED printheads when the cover is open. As a test, you can remove the 4 black protective covers from the printheads and see if your machine will calibrate itself. If it does, I recommend leaving the protectors off and just be extra careful of the LED printheads when you change toners...
Jul 06, 2013 | Oki Printing Solutions C9650 Led Printer
I have looping underneath. Top stitch looks great.
top tension is too loose,check threading up and tension dial. should be on 4-6. read manual and if possible clean tension device. if it is accessible you turn dial to zero and "floss" between tension discs using selvage edge of clean piece of cotton fabric. you can moisten it with denatured alcohol if very dirty. thread sheds dye particles, especially black or cheaper threads. needs to be removed regularly to keep tension discs clean. turn back dial to 5 after and thread up again. often this will resolve the problem
Aug 27, 2011 | Janome Memory Craft 9000 Computerized...
Power and warning light flashing on switch on
This error is detected when the protection counter A stored into EEPROM reaches the limit (32915 points). This means that the ink Waste Pads are full.
You need to do 2 things. 1. Reset the counter using the SSC Service Utility. Download from http://www.ssclg.com/.
2. Open up the printer and take out and clean the Waste Pads. You can get the Service Manual from http://www.2manuals.com/index.php. I did get one free from them(?) but can't find the link again. However I haven't succeeded in opening the printer! If you do succeed let me know.
Victor
rebrepsv@googlemail.com
Jan 22, 2010 | Epson Stylus C62 InkJet Printer
machine error a1 means: scanner open which is an info. You dont have to disassemble the ph!
Apr 06, 2008 | Brother DCP-110C All-In-One InkJet Printer
Thanks for your advice!
John,
the fixya message systems fools my email account since half a week. So, I m sorry, that I cant answer straight to your requests...
Now lets have a look at your prob:
And...
Apr 04, 2008 | Office Equipment & Supplies
Error A1
This is no error! It indicates that the scanner is open (what you have done to replace the carts or when there is a paperjam).
It might be that the ph is clogged (mostly due to generic ink).
Run the manual cleaning procedure 3 times!
If there is no more bk /y you need a new ph.
Mar 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Print and copy comes out blank paper - MFC-420CN All in one
mac,
I guess your machine has a serious problem with the purge unit.
Its indicated thru error 39. (the other ones are quite normal: A! menas Cover open (when replacing carts) and the 8x are related to paper feeder (running without paper/paper jam))
Have a look on the encoder disc which is positioned on one of the big white gear wheels on left hand side. Is it stained or broken/scratched? Do you hear scratching noises when machine is powered up?
Anyway its worth a look. But it could be that the print head has dryed out/clogged though it wasnt cleaned for a while.
If you cant get the error clear the only way to fix the machine is to replace the whole print unit including ph and cart holder (incl. tubes). This is quite simple to do because you can simply unplug the connectors on the main circuit (left hand side red/black cable), loose one screw which is within the metal (position near power inlet, can be seen from above), unfasten the cart holder connector to main board. Unfasten the two white flat cable of the ph.
The whole spare part can be used from a dcp 110c/dcp 115c which you can buy as a 2.hand one at eBay. HAve a look for a dcp with broken scanner glass ;-)
Dec 07, 2007 | Brother MFC 420CN All-In-One InkJet...
My mfc215c doesnt appear to recognise magenta
So let me give you some clues reading the recorded errors:
A1 : (even a brand new model has this error which simply means COVER OPEN/Close Cover (e.g. when installing carts)
38: puuuhhh error starting with a 3 has always to do with the traveling of the printhead.
Or there might be a defective part within the gear wheels.
84: something to do with the paper roller feeder (you might have run out of paper or paper wasnt feed in right position: some paperjam afterwards. This error can be related to error 38.
Anyway,
if you had done the maintenance cleaning procedures and didnt have any luck with good printing, there is only left to say:
print head clogged and needs replacement!
(The main reason for this is either having used generic ink which will definitely destroy the ph within some time period or you have paused the machine for too long time so that the ph has dried out.)
Dec 07, 2007 | Brother Multi-Function Center® MFC-215C...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
487 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
