Question about Electrolux Vacuums
Old vaccum retractable cord
I have an old Electrolux (model AP280)
I guess it's what you would call canister.
Everything with it work fine but the retractable cord doesn't retract.
I could try to repair it if I knew how to open it to get at the parts and have a closer look but I could no figure how to open the casing.
Can you help with that?
HD
This may come too late for you looking at the date of your posting. I have the same model and it stumped me for a bit too but I did get it open. It's real easy once you know how. Open up the front and remove the bag, then look at the side (beige) bumper strip that runs from front to back. This is splined. You can see it by looking carefully at the front. The brown case is held together by the splined rubber strip. Simply use a pair of slip joint pliers or a vice grip. Grab it and pull to the front. It took a bit to get it moving but then it slid right out. I found it easiest to place the vacuum on the floor, hold it with my feet and with the front open and the bag out I just grabbed the side strip with my pliers and pulled hard and it slid right out.
Good Luck.
Posted on Oct 25, 2008
Hello
I have the same Electrolux vacuum, and, I too could not figure out how to open it up.
Here's the site I found:--
http://www.howtomendit.com/answers.php?id=101957
HTH
Uncleclarence
Posted on Jun 03, 2008
SOURCE:
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
Need to open the canister to get to the cord assembly of my Electrolux Lux 5000
Why do you need to get to the cord assembly?
If the cord will not retract, tilt the vacuum to about a 45 degree angle and gently tug and release cord. It will usually retract.
Due to problems ensuing from untrained persons attempting to reassemble the vacuum and having to take it to the shop anyway, I recommend not taking it apart.
If the above isn't the problem, please take it to the nearest Aerus Electrolux store for repair.
http://www.aerushome.com/storelocator/
Jan 22, 2011 | Electrolux Lux 5500 Canister Vacuum
Model 720 vac the power cord will not retract
Lift the front of the vacuum so the canister is at about a 75 degree angle. Gently tug and release cord. It may take a few tries, but it usually works.
Jan 08, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
How do I open the canister of the Aerus Electrolux Lux Guardian? I need to replace the retractable cord mechanism. Aerus won't help me.
This will not be difficult to open, however, inside may scare you.
Remove your hepa filter cartridge (if you have one)
turn the machine over.
Undo the 6-8 screws there and pull the bottom off.
you should see everything there. If you are careful, just remove the old rewinder, and replace with the new one.
Good luck.
Mark
Nov 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Cord retracted into canister-how to take electrolux apart to get it out
You will have to take the cover off...it should be held together my a few screws. Just lay out everything in the orde that you take it off so it is easier to reassemble.
Jun 03, 2009 | Vacuums
Electrolux model 1401
try a local vacumn repair center or web site
Feb 04, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux lux vaccum cleaner hose and fitting/nozzle needed
Call your local Aerus/ Electrolux branch. If no luck with that try www.aeruspa.com
Hope this helps
Jan 09, 2008 | Vacuums
Vacuums Logo
774 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
