Computer My speakers arn't being recognized by my computer I've tried some suggestions as well as simple making sure connections are correct and restarting the comp nothing works. Also there is no speaker emblem in the bottom corner Please give me some suggestions
  • jengen Apr 09, 2008
    There was a yellow ? besides other devices & PCI devices Im not sure on what to do next thanks jen
  • 655 Answers
If you don't have speaker on Icon Tray (bottom right), means you have missing drivers for your Audio and if so you can't here any adio from your system. To find out whether you have missing driver or not, follow these steps:
  1. Click on Start -> Control Panel
  2. Double Click on system icon
  3. Click on Hardware
  4. Click on Device Manager.
Now the device manager window will appear. See carefully in the components list, if there is any component with yellow mark, then you have missing driver.
If you have missing driver then after installing the correct driver will fix your problem.
If you don't have driver tell me your manufacturer and model no. I will give you the link or you can find on the manufacturer's site.
If any question just Ask me.
Thanks
Iqbal
Posted on Apr 06, 2008
  • Iqbal Husain
    Iqbal Husain Apr 09, 2008
    Jen,
    Yaa am sure that might be your missing Audio device, that why you can't hear any sound from your PC.
    You need to install your Audio driver to work your PC. You should must have the driver for your device. If you have
    1. Right click on that icon
    2. Select uninstall from pop-up appeared
    3. Re-boot i.e. make re-start your PC
    4. Install the driver
    5. and finally................... :))
    If you don't have driver, please let me know your manufacturer and model no.
    Thanks
    Iqbal
SOURCE:
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
Dell 5650 speaker issues
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Dec 22, 2011 | Dell 5650 Computer Speakers
Logitech Z5500 5.1 speaker system Hi, Any suggestions on how to troubleshoot this problem? there is no sound coming from the subwoofer or the speakers, but when I connect my mp3 player to the pod...
Try pulling the power from the unit for a few minutes, the reconnect. Make sure you've got the surround settings correct. If that doesn't do it, you've likely popped the amp or the amp's power supply in the sub box.
Jun 16, 2011 | Logitech Z-5500 Computer Speakers
My system is not recognizing my delta66 hardware after a it triped of suddenly,i ve tried to reinstall but it kept saying "there is no delta hardware found in this system".pls i need ur advice on...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Feb 28, 2011 | M-Audio Delta 66 Sound Card
Logitech LS21 speakers connected to HP slimlie s5730f - barely any sound, volume adjustments make no difference. Doesn't recognize Logitech speakers under device manager.
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 16, 2011 | Logitech LS-21 2.1 Speakers
Speakers No longer recognized by my Computer! but pluged in right
Generally this is caused by a conflict of shared files. Try just rebooting your system, this will reactivate your sound card.
Jan 18, 2010 | Microsoft Windows XP Professional
No sound no nothing !
make sure :
1- the the speakers are connected to the sub woofer correctly
2- the sound driver is installed on your computer ( you can check that from Device Manager )
3- that you connected the sub woofer jack to the correct jack of your computer
4- the volume parameter is set to highest in your computer
if nothing works out then i suggest connecting the speakers to another device ( like ipod or mp3 player )
if either this won't work then the speakers are obviously corrupted :)
Dec 25, 2007 | Creative Labs I-Trigue 3600 Computer...
Subs
First of all you need to check if your amp can support this type of speaker setup? If you are simply going to wire 2 subs up to the amp (assuming a 2 channel amp) it's pretty simple. Just connect the + & - cables to one channel of the amp & the other ends of the cable to the sub, making sure that they are the correct polarity on both sides (ie speaker & on the amp).
If on the other hand you want to 'daisy chain' the subs onto one channel of the amp (this effectively drops the load down to half that of the speakers (usually 2 Ohm)), then you do as the name suggests. Simple connect one speaker cable to the amps channel 1 + ve output to subs_1 +ve input. Then from sub_1 -ve connector to subs_2 +ve. This leaves you with only 1 more to connect sub_2 -ve back to amp channel 1 -ve.
NOTE: make sure that your amp can support this first! If it can't then it's will auto switch off in most cases but can also damage the amp if there is no fail safe circuit built in.
Dec 24, 2007 | Rockford Fosgate FNQ1404 Car Speaker
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Open Questions:
Computers & Internet Logo
53 people viewed this question
Ekse
Alun Cox
