Question about Linksys WUSB54GC 802.11g/b Wireless Adapter
Not able to go on line
Cannot see w/l signal
    Sergeant:
    Champion:
  • 293 Answers
Reinstall the driver first and then plug in the unit
Posted on Apr 08, 2008
SOURCE:
Landline and internet not working
Follow the following steps:
1- Check your landline. If there is a tone signal or not. In case there is a signal go to step 2. In case no signal, contact your telecommunication company service center in order to repair your telephone line.
2- connect your telephone line to small device called filter signal. this device has one input (for telephone line) and two output line (one for your telephone system and other for ADSL your router)
3- You have to configure your router to connect to Internet.
For more details bout router configuration, contact me on [email protected]
I hope this help you.
Aug 04, 2017 | Internet Computers & Internet
Why does my tv has a line in the middle of it
Is it a vertical line or horizontal line? Does the line go away when you turn the TV off? If the line goes away when you turn the TV off, it is probably due to the "signal". Does the line go away with different inputs? If so, the cause is the specific input signal.
Apr 02, 2012 | Sylvania Televison & Video
How do i get stronger signal
If you are referring to a cable signal on your tv set, then there are several ways, but first off, how do you know the signal is weak? Analog cable signals typically run at 30 to 40 percent while HD signals on the same line can be as high as 90%.
If your cable connections are firm and have no fray with good cable runs, and is not longer than needed, I would suggest calling the cable company tech support line for troubleshooting. It could be their error in an outside line.
Mar 23, 2011 | Dynex DX-LCD37 TV
Line in what is that for
In general:
Line In is the standard name for any generic audio input. Line Out would be for the corresponding output.
It allows a standard for audio equipment manufacturers to use when designing for interconnection.
http://en.wikipedia.org/wiki/Line_level
"Consumer electronic devices concerned with audio (for example Sound cards) often have a connector labeled "line in" and/or "line out". Line out provides an audio signal output and line in receives a signal input. The line in/out connections on a computer sound card are generally unbalanced, with a TRS connector of 6.35 mm (1/4"), 3.5 mm (1/8" miniature) or 2.5 mm (3/32" subminiature). The connections on most other consumer equipment use RCA jacks. In most cases changing the volume setting on the source equipment does not vary the strength of the line out signal."
Jan 11, 2011 | RCA Electronics - Others
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
Vocopro sub 1500 ...looking for impeadence of speaker
Line level is known as 600 ohm line signal where the output impedance is 600 ohms and the input impedence is between 10,000 to ~ 50,000 ohms. There are normally no issues when connecting line level to line level. It is meant for transferring signal, not power.
Sep 27, 2009 | Audio Players & Recorders
Connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Sep 06, 2009 | Yamaha RX-V659 Receiver
Brother Inellifax 4100e will not send
It appears that you have interference somewhere in the office. Have you recently gone to DSL in the office? A DSL line transmits a signal that requires a filter to receive only phone signals instead of the DSL signal. If the fax machines are receiving an unfiltered DSL signal, this would explain the interference. If this is not the case, the link below is a Brother's Solution to the NG Poor line quality. Best of luck to you with your fax problem.
Greg
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000200/000009/faq000209_002.html?reg=us&c=us_ot&lang=en&prod=mfc6490cw_all
May 12, 2009 | Brother IntelliFAX 4100 Laser Fax
What is modem
Modem:
1) A device (modulator/demodulator) that allows computer information to be sent over a telephone line.
2) Equipment that converts digital signals into analog signals for purpose of transmission over a telephone line. Signal is then converted back to digital form so that it can be processed by a receiving computer. Modems are typically used to link computers via telephone lines. ...
3) Acronym for MODulator/DEModulator. A device that transforms digital signals from the computer into electrical impulses for transmission over telephone lines, and does the reverse in reception.
4) A modem (from modulate and demodulate) is a device that modulates an analog carrier signal to encode digital information, and also demodulates such a carrier signal to decode the transmitted information. A device that transmits digital data in tones over a phone line.
IN GENERAL IT IS A DEVICE TO CONNECT THE COMPUTER TO THE INTERNET.
For more detailed info about the modem click here
Hope this helps
Sammy
Sep 04, 2008 | Computers & Internet
LOOSE SIGNAL WHEN I CROSS THE STATE LINE
well acually it depends on the signal availablity and mobile phone other then nokia are having a weaker mobile recevier but something there is nothing wrong with the phone it's the signal which are comming weak for the network caused this problem
Sep 24, 2007 | Motorola Mobility RAZR V3
Linksys WUSB54GC 802.11g/b Wireless Adapter Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
