Question about Microsoft Windows XP Home Edition
Restarts after XP loading screen due to SP2
This is on a new computer with only WinRAR and a driver(Marvel ?????) for my ethernet port on it.
I recently installed XP Service Pack 2 on my computer which has XP Home Edition on it. When it restarted it said that something happened and gave me the choice on how to start up. If I choose normally or last known good configuration then it goes until the screen that says WINDOWS XP and then restarts. It will start in safe mode, which I did and uninstalled the SP2 and then the computer started fine. I tried reinstalling it and the same thing happened again. I need the service pack so the computer will recognize my two 300 Gb harddrives (it says they are only 128 right now). What do I do. Thanks to anybody who takes the time to write a response.
  • Jadder Apr 07, 2008
    Repairing deletes SP2 and if I reinstall it the same thing happens. But I-tunes and Windows Media Player 11 both require it, so I need to try something else.
  • Amber Engman May 11, 2010
  • Microsoft Master
  • 1,183 Answers
1, the problem can be resolved repair, reinstalling windows.
Boot from the windows Os cd , Press Enter on the first prompt, Accept the liscense agreemt by pressing F8 and press R on the third screen to repair windows.
You also told that the hdds that you are istalling are 300GB each,in some cases you need to install the hdd drivers to get them to recoganise them correctly . The same is given by the manufacturer on a CD.
Posted on Apr 06, 2008
  • Mandeep  Singh
    Mandeep Singh Apr 07, 2008
    Go in for a lower capcity hdd, rather than 300 gb . I suspect your motherboard is not supporting your configuration. Coz if its doing the same thing after repair and reinstalling the OS, it has to be something with the hardware.
FROM WHERE CAN I DOWNLOAD WINDOWS XP SP2 LAN DRIVER FOR HP PROLIANT ML110 G6
Hi ppswalia
Since this is a Server, rather than an ordinary Desktop computer, it is not designed to work with normal Windows XP Operating Systems. It is designed to work specifically with Windows, Unix and Linux Server Applications. See here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
There are 2 things you can try.
You can try installing the LAN/Ethernet Drivers for the various Windows Server versions from the above official HP Downloads and Drivers Support Website and see if one of them just happens to coincidentally be compatible with XP SP2.
Assuming there are no further compatibility issues between other Server Motherboard Devices and Win XP SP2 Drivers, you could open the Server case and either bypass any on-board LAN/Ethernet/NIC Port or remove any separate LAN/Ethernet/Network Card installed and install, instead, a pre-confirmed Win XP compatible LAN/Ethernet/NIC Card and then install the drivers for the new card.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 18, 2011 | HP ProLiant ML110 Server
I loaded xp pro but my ethernet port is not active. Do I need to load ethernet drivers?
That means that the operating system doesn't have a database for your Ethernet device. You have to have the driver that came together with your PC and you should find the driver for your Ethernet device using that.
Sep 13, 2010 | IBM ThinkPad T42 Notebook
I tried to install Windows XP sp2 and the windows boot screen did not show up.
Reinstall and during the install press F6 when it ask if would like to install 3rd party drivers and have the driver disk for your hard drive ready and install those when ask.once it is done it should complete the xp install and restart correctly.
Jun 01, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
LOST ETHERNET DRIVER
If you have the "Windows XP" operating system then follow these instructions...If you have a second computer with an internet connection then you can search on the internet for that driver...type the make and model of your computer plus the word "ethernet driver" and after you find it you just download it into "My Documents"...after that, copy the driver onto a blank CD disc...Take the CD and put it into your notebook and it should open and extract the file ..If it doesn't open up when you load the CD, go into "My Computer" and then double click on the "CD/CDRW/DVD/DVD-RW drive...restart your computer and remove the CD from the disc drive...Now plug your DSL into your ethernet port and see if it works...if it still does not work then go into "Control Panel" and then "Network and Internet Connections" and then "Network Connections" and then "Create a New Connection" and then follow the instructions...restart your computer and see if it finds the ethernet port and receives the signal through the ethernet cord
Apr 18, 2009 | Computers & Internet
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
Dec 31, 2008 | Microsoft Windows Xp Home Edition Sp2...
Problem with Restarts
this problem may due to virus , so better you reinstall your system
Aug 28, 2008 | Compaq tc4400 Tablet PC
My pc restarts automatically after installing each driver / software
some brands pcs are programmed to reboot after they load drivers the drivers wont load to trigger the hardware til you reboot...
Aug 28, 2008 | Logitech Webcam
USB 2.0 doesn't work on K8MM-V with XP PRO SP2???
hey!
ok now the K8MM-V has several 'chipsets' yours has 8 usbs? yes?
then you have the:
VIA VT8237R Chipset...
- Integrated Faster Ethernet LPC
- Integrated Hardware Sound Blaster/Direct Sound AC97 audio
- Ultra DMA 66/100/133 master mode PCI EIDE controller
- ACPI
- Supports 2 Serial ATA ports
- Supports 8 USB2.0 ports
ok? now:
download a new BIOS! this means read the readme.txt please!
http://global.msi.com.tw/index.php?func=driverfile&dno=2383&i=1
<<this is the xp(64bit driver set>> (incase you are missing the 2.0 or yours is corrupt)
http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=173
this is your BIOS (as i said please follow ALL instructions cause its inportant)
good luck!
after BIOS flash and driver updated go into the control panel > admin. settings > computer managment > device manager then look at the USB section and update the drivers!!
rerstart and volla!
good luck!
Oct 13, 2007 | MSI K8MM-V Motherboard
Microsoft Windows XP Home Edition Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
