When try to install ccomand and conquor it keeps coming up with can not start epson scan
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 11, 2010
    what operating system are you using? do you have an epson scanner, which model?
    Genius:
  • 1,447 Answers
Click on your drive E or explore the command and conquer disk if ur using any and lok for the setup executable. If this is a downloaded file make sure yu are clicking on the right icon. update me with additional info so that we can work this one out. thanks!!
Posted on Apr 06, 2008
Cannot scan or print with epson stylus cx5900, working with mac os x version 10.5.8 even though already download driver update from epson website. when printing, error show printer is offline. when...
Try uninstalling, then installing the driver fresh. NOT an update. You could also have a bad printer cable, borrow one from a friend. No sense buying one as almost all new printers come with one!
Nov 02, 2017 | Epson STYLUS CX5900 Printer
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
Having trouble getting printer to work
you probably has to go to epson website to see if they have new drivers for windows 7 and machine
unaasp192
Apr 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have escndv.exe error problem with 4490 scanner. I've reinstalled the drivers and it still comes up
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=50666&infoType=Overview
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
corrupted.
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Reboot:
Install Epson scan.
Good Luck!!
Jul 03, 2009 | Epson Perfection 4490 Photo Scanner...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I have an Epson Perfection 3590 Photo and when I tried to open it this appears:"escndv.exe has encountered a problem and needs to close. Sorry for the...etc." I have already downloaded the Epson Scan...
This file that cannot be found "DICElib.dll" is actually installed by the LaserSoft SilverFast driver that comes with both scanner models. This file gets placed in the Epson Scan folders during installation because the LaserSoft SilverFast Driver works in conjunction with the Epson Scan driver for communication to the scanner. The solution to this issue is to uninstall and re-install the LaserSoft SilverFast Driver and NOT the Epson Scan driver.
On the "Start Here" poster it says that you have to install the Epson scan driver first before installing the LaserSoft SilverFast. Other possible causes are that the file has become corrupt, has been moved or has been deleted.
If this will not work, please call epson technical support. They have troubleshooting steps for that type of issue that cannot be disclosed here.
Please let them know if you have any other scanners or digital cameras installed on your system. If so, provide the model and manufacturer.
Sherlyn C.
Apr 16, 2009 | Epson Stylus CX6000 All-In-One InkJet...
How to scan on an Epson Stylus DX4400
To scan an image into your PC you need to use a piece of software called the Epson Scan Utility. This
comes on the installation CD with the printer but if you don't have the CD it can be downloaded from
Epson Support. For Europe:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84YT0DcLI1RrpNUFXBv2
99cYU003D
Or US:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Once it is installed it will put an icon on the desktop, or (if you have Windows) a folder in the Start
menu. Turn the printer on and start the Epson Scan utility (it doesn't work if the printer is off), it
can be used in 3 modes: Fully Auto, Home Use or proffessional. Fully auto is the simplest, just click
on the scan button. For the others be brave and experiment!
Please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Office Equipment & Supplies
Scanning on an epson dx4400
To scan a picture into your PC you will need the Epson Scan program installed on the PC. This program comes on the CD with the printer, but if you don't have the CD it can be downloaded from Epson:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cxyWBIk5wgudexhHWUK6Mnk&tc=6#19
It may already be installed, if you have Windows go to the Start menu and look for Epson Scan Utility. Turn the printer on and place your photo on the glass under the scanner cover. Click on Epson scan and you can choose 3 methods. Fully automatic, home mode or proffessional mode. fully automatic is the simplest method, simply click on the scan button. For the others be brave and experiment!
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 31, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
Scanner will not work!
One more try - this way
Remove all previous installations using the the Epson uninstall feature9Go to start/Programs/Epson side menu - uninstall.
Do this to all Epson modules.
No go to Start/Run in the filed type -REGEDIT
IN Edit[on the top bar] cclick on 'find.' in the field type EPSON
delete all that comes up.
Restart the machine.
Make sure you are offline.
Disable the Antivirus software.
Making sure the Software CD it spotless clean put in the drawer and follow the prompts.
Come back with with results - goood or bad
Nov 26, 2007 | Epson RX620 All-In-One InkJet Photo...
Computers & Internet Logo
David Payne
David Payne
