Question about Canon CanoScan 8400F Flatbed Scanner
Scanning B+W shows dots
Hello
hope u can help.
I am trying to scan a black & white picture about 5x7 inches.
Using canoscan 8400F scanner.
I am scanning at 300DPI with the Descreen ON.
Showing dots all over the picture.
What can I do to prevent this.
Picture is in a b00k & is slightly glossy.
Hipe u can help.
monica
    Scholar:
  • 111 Answers
Don't use Descreen. That is for scanning things such as Magazines that, when looked at very close, appears to have a lot of little dots that can cause a moire pattern when scanned.
Posted on Jul 09, 2008
Can I scan a negative 4X5 black\white to make a photo
In general, yes, you can scan a negative and make a photo from it. I don't really know your model scanner, my Canon 8400f has a film adapter and a light in the cover, but would have to scan a 4x5 in sections and I would have to piece it together after scanning.
The results I get from scanning negs are very good, as good as I ever got in my darkroom.
Oct 31, 2014 | Canon CanoScan 8800F Flatbed Scanner
CanoScan 8400F Cannot scan for these reasons: -The
You have a bad scanner lamp, but they are not available as a spare part.
Nov 14, 2009 | Canon CanoScan 8400F Flatbed Scanner
I get an error code 2,178,0 when i try ot scan
First, make certain that the flatbed scanner lid is securely shut.
Second, unplug the power and USB cables from the rear of the scanner.
Third, deposit the Canon 8400F scanner in the nearest garbage receptacle where it belongs.
Hope this helps.
Sep 28, 2009 | Canon CanoScan 8400F Flatbed Scanner
Dark streak when scanning film on canoscan 8400F
please clean scanner mirror then solve this problem
Sep 06, 2009 | Canon CanoScan 8400F Flatbed Scanner
I want to save scanned document as a .doc using CanoScan 8400F
Scanners only see millions of dots. Unless it has software to convert a picture into a document, all documents are seen by scanners as pictures made of of millions of dots. Software is available to convert it to a Microsoft Doc format but it is very expensive.
Apr 19, 2009 | Canon CanoScan 8400F Film Scanner
CANOSCAN 8400F 35mm SLIDES PROBLEM
Please see my other postings (wireguy) regarding this same problem. It's caused by a faulty FAU cable.
Feb 09, 2009 | Canon CanoScan 8400F Film Scanner
Canon 8400F scanner refuses to scan 12 negatives at a time. Preview shows them all, but the "select all frames" is grayed out, and refuses to function. I can scan manually one negative at a time among...
Check to see if the "Thumbnail Display" is on or off (first icon on the toolbar in the ScanGear CS window). If it is on, a colored border will appear around one of the images in the preview display, but you will not be able to select all frames. If you click on the Thumbnail Display icon to turn it off, only a dotted line will appear around one of the images, but you will be able to click on the "select all frames" Apply button.
Dec 09, 2008 | Canon CanoScan 8400F Flatbed Scanner
Canoscan 8400F problem
If possible, try it on another computer. If the symptom is the same, then the scanner requires service.
Jul 17, 2008 | Canon CanoScan 8400F Film Scanner
How do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Jul 07, 2008 | Canon CanoScan 8400F Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
117 people viewed this question
old marine
old marine
