Question about Cameras
A Pentax Espio 135M Multi AF Auto Focus 35mm Compact Camera with a SMC Pentax 38mm to 135mm Zoom Len
The lens protection device of a camera I recently purchased does not open fully. It only opens about 1/2-way. The 4 little flaps are opened by 2 pins and they don't seem to be moving all the way across when the camera is turned on. Would I have to open it further to find what the problem is? If so, do you have an instruction procedure for this?
Thank You,
Kene
  • afriken Apr 06, 2008
    Are there User's Manuals available on the Web?
    ps my name is Ken , not Kene!
I sounds like your shutter is stinking dont remove or losen the screws there are manuals on the web. find out what type a camera it is then go to the retail on the web they should have support or manuals for you
Posted on Apr 09, 2008
Will lens from a sf1 fit the newer models like the Kr or better
Yes. The new digital model cameras will accept the older K-AF lenses.
Mar 01, 2013 | Pentax Sf1 35mm Slr Film Camera 35-70mm...
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
I was given a 35mm pentax espio 70 zoom camera recently but I have no instruction leaflet with it. Is it possible still to get one.
Most documentation is available online. Use the search engine of your choosing to look for:
Camera manufacturer + model + manual
I believe you can find it here:
http://www.pentaximaging.com/support/manuals-and-literature/
Feb 28, 2011 | Pentax Espio 738S 35mm Point and Shoot...
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
Camera will not auto focus
Take the lens off and rotate the focus ring, it should turn very easily with little gear noise.Try a different AF Pentax lens that you know is good.
I'm sure the lens is binding, take the lens to a camera repair shop for an estimate cost to repair.
Dec 10, 2007 | Pentax PZ-70 QD 35mm SLR Camera
Zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
Cameras Logo
247 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
