Question about Canon Rebel XT / EOS 350D Digital Camera
Batter won't hold it's charge if left in the camera overnight
Unfortunately all is not well with my Canon EOS 350D camera, the battery originaly supplied with the camera won't hold it's charge if left in the camera overnight but holds it's charge is left for two days in the bag. So I thought that I needed a new battery, this was ordered and this too will not keep it charge in the camera overnight. Any suggestions?
  • 3 Answers
Apparently you shouldn't leave the battery in the camera when you're not using it - the on/off switch doesn't turn the thing off completely. Weird!
Posted on Apr 10, 2008
SOURCE:
EOS 350D
When you change the zoom, chances are the camera lose focus, and you need to half-press the shutter button again to the camera autofocus.
Its normal behavior to lose focus when zooming in or out.
May 06, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I just purchased a new battery since the old one would not hold a charge. It appears the new battery does not hold a charge more than a few hours as well.
I would seek a replacement battery from the source of your new battery which should be under warranty. Don't wait too long to do this, as the replacement or refund will have a time limit of less than 30 days in many cases.
Dec 31, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Will not turn on
Old batteries will not charge fully. Batteries left to completely discharge will most likely be useless.
Oct 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera made a POP noise Canon Digital Rebel
Unfortunately, per your problem description, it seems that an electronic device in one of the internal baords is damaged, causing a failure in the power board.
The solution for it requires to open and repair the damaged board, or replace it. This means that it has to be done by a professional repair service.
If your camera is within warranty, contact immediately to Canon to make it valid. If not, then contact a camera repair center for diagnosctics and repair quote.
Best regards,
Jul 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera drains charged batteries
Most likely your batteries are just not holding a charge. However, before you spend good money on new batteries, try charging them on another charger (friend or sympathetic photo shop?). Could be the charger also. Usually it's the batteries, though.
Mar 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
213 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
